It is currently Sat Sep 13, 2025 3:51 pm
 Post subject: Reset on Laminated neck
PostPosted: Mon Nov 10, 2014 1:23 pm
Theres are a couple of pics on the building forum of an archtop Im planning to fix.
It needs a reset but has a Laminated neck..
Anyone have experience of this? did the steam unglue the neck Lams?
These are the laminate that run all the way to
the heel
PostPosted: Tue Nov 11, 2014 7:14 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Archtop necks are tougher to steam out than flat tops. I recently did a Hofner bass and there was some slight separation of the laminated and stacked heel.
Brian
PostPosted: Tue Nov 11, 2014 4:13 pm
I decided to go for it
all went pretty well...i was a bit concerned as this was a laminated back also
The back was fine, the tenon had split a bit but glued back up well...nothing too pretty in there
There was a "truss" rod of sorts in there also!
