It is currently Sun Sep 14, 2025 3:10 am
PostPosted: Mon Dec 14, 2015 7:26 pm
First name: Mark
Last Name: Gammell
State: NE
I'm working on a Gibson Thunderbird bass. The pickup screws keep working their way out, and when I took them apart I saw that they screw into wood, with a spring on the screw between the pickup and the body. No surprise there, but I question the wisdom of having an adjustment screw screwing into wood. So far I've just filled 'em and drilled 'em, and that works, but I'd like to find a more permanent solution.
Is there a place I can look to get a metal insert/bushing to put in so the adjustment screw goes into metal? I can get the exact parameters if necessary, but for now I'm just wondering if such an animal exists. The screws are black, so if I have to replace them I'll need black ones, as any other color on this thing will look out of place.
"Real guitars are for old people, Mr. Marsh."
Eric Cartman
PostPosted: Thu Dec 17, 2015 6:26 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
Yes. McMaster-Carr sells several types and sizes of threaded inserts for wood.
See: http://www.mcmaster.com/#standard-threaded-inserts/=10a7w3j
PostPosted: Fri Dec 18, 2015 1:37 am
First name: george
Last Name: s
Also, Rockler, and I may have seen them at Lowes. You may have to trim them down, so you don't accidentally pop through the back. I say this not so much for you, but to remind me :-)
