It is currently Sun Sep 14, 2025 5:03 pm
 Post subject: Semi-hollow Rewiring
PostPosted: Thu Sep 24, 2015 1:26 pm
First name: Rudy
Last Name: Bless
City: Chicago
State: Illinois
Zip/Postal Code: 60647
Howdy, new guy on the boards here.
Sorry if this has been posted already, I used the search function but wasn't able to find anything.
I'm working on repairing the wiring on a Hezz semi-hollow, and have run into a small issue. I have the pots sunk into the body (still accessible with floss, a crude but effective method) but am still unable to properly access the pots themselves. The first issue is that the components wired between the pots don't allow for the necessary maneuverability, but the main issue is that the f-holes themselves are too small to pull the entire wired array out of the cavity. I've attached a few links to pictures to illustrate the issue. (file sizes were too big to attach directly)
I was wondering if anyone else has come across this, and if so (or if not) have any recommendations as to how to access the electronics?
Thanks!
https://www.dropbox.com/s/28so4ol6h1rad ... 3.jpg?dl=0
https://www.dropbox.com/s/92fe0xj1tl2a8 ... 4.jpg?dl=0
 Post subject: Re: Semi-hollow Rewiring
PostPosted: Thu Sep 24, 2015 1:36 pm
Take out the bridge pickup and you'll have a big hole to draw out the wire, pots, jacks, and all.
These users thanked the author Chris Pile for the post: basskidd (Thu Sep 24, 2015 2:00 pm)
PostPosted: Tue Oct 06, 2015 12:13 pm
A few things to check:
Ground wire? Is that holding it up?
Output Jack? Is that holding it up?
