Towel marks from waxing
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10137&t=48544
Author:  FL6 [ Tue Nov 15, 2016 4:26 pm ]
Post subject:  Towel marks from waxing
I'm a beginner in terms of refinishing guitars, electric specifically.
My issue is after wet sanding the laquer clear coat down to 2000, I then applied wax.
I applied it by hand on both sides but somehow the towel that the guitar was resting on as I waxed has made an impression fairly deep into the finish.
Was heat the cause?
Should the guitar not be flat on a clean towel when buffing/polishing?
The good news is on a test guitar I got my technique down when I changed to compounds and omitted wax but I'm worried about making the same mistake again.
So I saw what happened but not sure why.
Thanks.
Author:  Alex Kleon [ Tue Nov 15, 2016 5:51 pm ]
Post subject:  Re: Towel marks from waxing
What kind of wax, Paul?
Alex
Author:  FL6 [ Tue Nov 15, 2016 6:23 pm ]
Alex
Mothers carnauba wax
Author:  dzsmith [ Tue Nov 15, 2016 7:03 pm ]
Sounds like the finish was not hard yet.
Author:  FL6 [ Tue Nov 15, 2016 7:08 pm ]
I wondered about that. I let it hang for 6 weeks but I did put a lot of coats on.
Author:  Alex Kleon [ Tue Nov 15, 2016 8:42 pm ]
Could there have been some solvent on the towel? That could soften the wax, even if there's a hint of it.
Alex
Author:  FL6 [ Tue Nov 15, 2016 10:35 pm ]
Alex
I don't think so but now that I think about it, it was an old towel. I'll test a small area with a different towel. Thanks.
Author:  B. Howard [ Wed Nov 16, 2016 7:45 am ]
What brand and type of finish?
Author:  FL6 [ Wed Nov 16, 2016 8:48 am ]
Duplicolor clear coat.
Author:  B. Howard [ Thu Nov 17, 2016 8:11 am ]
Not to familiar with the duplicolor stuff but I have seen issues with other rattle can brands (most notoriously Deft) Taking months to harden and then never really achieving the hardness I would expect of a nitro lacquer.
Author:  FL6 [ Thu Nov 17, 2016 8:31 am ]
Yeah this is possible too. I'm going to wet sand and buff with compound and see where it gets me. Thanks.
Edit: I think it's not hard. I haven't come across a hardness test but I noticed someone in another forum said to check if you fingernail can make a dent. Well mine did, I went easy so it's not deep but looks like I'm going to have to keep waiting.
Is there a repair procedure for clear coats? Could I take it to a professional shop and have them add a few coats? The paint job is rather intricate, I would rather not start that over. :shock:
Author:  B. Howard [ Fri Nov 18, 2016 8:11 am ]
IME the only solution is to remove the soft lacquer and re-finish. If you put a harder coating over a softer one it will crack and peel....
Author:  FL6 [ Fri Nov 18, 2016 8:43 am ]
So just sand down to the paint?
Author:  Rockinrob86 [ Mon Nov 21, 2016 11:10 am ]
It's going to be extremely hard to not sand through - I usually chemically remove nitro. what did you paint it with?
