StewMac sanding stick stuff http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10137&t=52469 |
Author: | Chris Pile [ Wed Sep 25, 2019 11:56 pm ] |
Post subject: | StewMac sanding stick stuff |
I assume you are familiar with StewMac's sanding stick for working frets? This thing… ![]() The sanding strips are troublesome when they get old. The glue fails on the fiberglass reinforcement strip. And then the barely used sanding strip gets tossed. I had enough, and like a lot of frustrated luthiers - I saved the strips in a baggie for reuse sometime in the future. Now I am supergluing these strips back together so I can use up ALL the abrasive. Just takes a dot of glue, and a quick pinch until it cures. If the reinforcement tape fell off, you can still superglue the strip together by overlapping it. Works fine. Just don't locate the glued joint near the point of the sanding tool, or it will come apart. Thusly... https://imgur.com/T0iCGKb https://imgur.com/ZQHThw4 And now back to work.... |
Author: | Smylight [ Fri Sep 27, 2019 9:48 am ] |
Post subject: | Re: StewMac sanding stick stuff |
Thanks for sharing. This tip gets filed with a lot of others in the back of my mind. Pierre Guitares Torvisse |
