how to shine/polish a guitar table after sanding with 1000gr
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10137&t=53575
Author:  the_doc735 [ Thu Oct 08, 2020 4:42 pm ]
Post subject:  how to shine/polish a guitar table after sanding with 1000gr
how to shine/polish a guitar table after sanding with 1000grit paper?
I just dropped some black super glue on the table of my PRS SE, rubbing alcohol didn't even touch it! Neither did 2500 grit paper so I used 1000 grit paper which removed the glue but has left the surface dull/rough/matt, and the shine has gone!
Is there a way to restore the shine without clear coating the whole thing?
I tried some D'Addario PW-PL-02S Liquid Carnauba with a microfibre cloth without much success, but I only did it briefly!
many thanks!
Author:  Glen H [ Thu Oct 08, 2020 5:07 pm ]
Post subject:  Re: how to shine/polish a guitar table after sanding with 10
Go back to your 2500 grit and work the area. You may need to use some interim grits. Then work it with rubbing compound then polishing compound
Author:  Freeman [ Thu Oct 08, 2020 6:12 pm ]
What Glen says. Go back up the grits from 1000 - 1200, 1500, 2000 and your 2500 (wet). Then polish with a good compound (I use Meguiers #2 and 3) without wax or silicon.
Author:  the_doc735 [ Sun Oct 11, 2020 11:11 am ]
I'm getting these:
https://www.ebay.co.uk/itm/K2-GOLD-LUSTER-Q5-FINE-CUT-Compound-Polishing-Car-Paint-Acrylic-NO-SWIRLS-Gloss/162466877160?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.premiumhobbies.co.uk/polish-wax/foam-polishing-pad-kit
Author:  Barry Daniels [ Sun Oct 11, 2020 5:36 pm ]
That is a very fine compound and might not be enough to get out 1000 grit, or finer, scratches. You might want to start with a more aggressive cutting compound.
Author:  the_doc735 [ Tue Oct 13, 2020 8:55 am ]
What would you suggest please?
thanks!
Author:  Barry Daniels [ Tue Oct 13, 2020 9:12 am ]
There are a lot of compounds that would work, but this is my preference:
https://www.amazon.co.uk/Meguiars-Mirror-Glaze-Ultra-Cut-Compound/dp/B01LRHDOUC/ref=sr_1_1?dchild=1&keywords=meguiars+105&qid=1602598287&quartzVehicle=106-1339&replacementKeywords=meguiars&sr=8-1
Author:  the_doc735 [ Thu Oct 22, 2020 5:17 am ]
I used 1500, 2000, 2500 papers and these:
https://www.ebay.co.uk/itm/K2-GOLD-LUST ... 2749.l2649
https://www.premiumhobbies.co.uk/polish ... ng-pad-kit
It worked very well!
Many thanks for all your guidance, much appreciated to everybody here.
