Simple Jig for Cutting the Headplate Square to the Nut Slot http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10146&t=48697 |
Author: | ericschaeferguitars [ Thu Dec 15, 2016 9:46 am ] |
Post subject: | Simple Jig for Cutting the Headplate Square to the Nut Slot |
Author: | Ed Haney [ Sun Aug 20, 2017 8:57 pm ] |
Post subject: | Re: Simple Jig for Cutting the Headplate Square to the Nut S |
This method is fine, but appears only to even be needed because of the author's building sequence. I install the truss rod and glue on the fretboard before I glue on the head plate. That way, with the fretboard end in its final resting place I place the nut I will acutually be using against the end of the fretboard, and then place the square head-plate against the nut and glue on the headplate in everything in exact place. Now there's a perfect fit of the fretboard, nut and headplate without the need to cut the head-plate at all. (You may ask, "how do you get the correct angle on the nut end of the headplate?" I set my disk sander to the the headstock angle and then touch the headplate end against the sander before I glue on the plate.) I recognize that there are many many possible sequences for building and no sequence is without its challenges. |
Author: | Ruby50 [ Mon Aug 21, 2017 10:17 am ] |
Ed I do the same thing, except I don't glue on the fretboard, only set it on its register pins. With the fretboard off, I have more options for shaping and handling the neck. The angle at the nut end of the head plate is easy to get with a sanding block, too. Ed |
Author: | johnparchem [ Mon Aug 21, 2017 10:54 am ] |
My one fear with the jig shown is over cutting and leaving a small cut in the neck. I am sure you manage it cleanly. I wait to glue on the headplate until I have properly positioned the fretboard, not glued just positioned with location pins and clamped. With the fretboard in place I position a nut spacer against the fretboard. I use a belt sander to put the correct angle on the nut end of the headplate. At this point I can glue on the headplate with the correct angle on the nut end in the correct location. No cutting or trimming on the neck and always square to the fretboard. |
Author: | Imbler [ Mon Aug 21, 2017 12:07 pm ] |
I just use my tablesaw. I make sure I keep a squared edge on one side of the neck; Place the neck on a scrap of plywood to keep the headplate off the table, raise the blade while spinning slowly by hand to where it just touches the neck, then back off a skosh. Put the squared side of the neck against the miter and just push through to cut. Easy peasy and nice and square in both planes. |
