It is currently Wed Jul 30, 2025 2:58 am
PostPosted: Wed May 23, 2007 3:25 am
Hi guys,
here one of my latest guitars.
Curly Koa back and sides with a Semi-double Curly Redwood Top. Amazing tap tone from the box.....
PostPosted: Wed May 23, 2007 3:53 am
Those are some pretty woods Peter.  What, for the newbie, is a semi-double top?
PostPosted: Wed May 23, 2007 3:54 am
Sweeeet
PostPosted: Wed May 23, 2007 4:31 am
I too would like to know more about your semi-double top Peter.
PostPosted: Wed May 23, 2007 10:12 am
Last Name: Lloyd
Interesting choice of woods. Quite striking.
Dido on the semi-double top.
Michael Lloyd
PostPosted: Wed May 23, 2007 1:40 pm
Peter,
   That is some beautiful wood.....all the way around! I look forward to seeing
it progress into one of your typically gorgeous instruments.
    I'm hoping to be able to play one of your double topped pieces in the
future. I've done the Nomex suspended top plates a few times and really
liked to results.
    Please post some pics as this guitar comes together.
Kevin Gallagher/Omega Guitars
PostPosted: Wed May 23, 2007 1:59 pm
Another bold, beautiful statement Peter!
What are you planning to use for bindings?
PostPosted: Wed May 23, 2007 2:29 pm
Thanks for the compliments!
This is another commissioned guitar that I am working on. it will be bound with Brazilian Rosewood and the top done in Paua Abalone.
PostPosted: Wed May 23, 2007 3:46 pm
Very Nice and unique combination!!!!
PostPosted: Wed May 23, 2007 4:27 pm
I'll go into the my semi double top details tomorrow... too late!
PostPosted: Wed May 23, 2007 5:14 pm
My gosh Peter, you know how to build glamourous but stylish guitars!!!
PostPosted: Thu May 24, 2007 2:25 am
Semi-double top construction is a simple method to strengthen figured soundboards that otherwise wouldn't be stable enough to use. All I do is trace the bracing pattern onto a spruce top that will be used as the backer for the top, then I remove wood from some of the areas surrounding the braces leaving only connecting areas to keep the integrity of the backer top. Then I glue both tops....VERY IMPORTANT....using a vacuum bag. If you don't have vacuum ability DO NOT do it as you won't be able to evenly distribute gluing pressure and may compromise the stability of the top.
PostPosted: Sat May 26, 2007 4:04 am
That redwood is sure prudy! Good work Peter!
PostPosted: Sat May 26, 2007 7:23 am
Last Name: Sydenstricker
City: Oscoda
That is so nice!
What type of finish will it be getting?
John S.
