It is currently Sat Jul 19, 2025 7:26 am
 Post subject: Ibex bending iron needed
PostPosted: Thu Jan 31, 2008 5:23 pm
Does anyone have an Ibex bending iron, 120V American version in good working condition that they'd consider selling? Thanks!
PostPosted: Thu Jan 31, 2008 5:57 pm
Terry, I think both Stew Mac and LMI carry the Ibex bending iron.
PostPosted: Thu Jan 31, 2008 6:21 pm
There is a 220v model on ebay right now (new), and there was a 110v model on there last week... probably the same seller...
PostPosted: Thu Jan 31, 2008 7:20 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Hi Terry,
Pilgrims Projects has a 120 volt Ibex Bending Iron for $125.00
http://www.pilgrimsprojects.biz/index.html
PostPosted: Thu Jan 31, 2008 8:27 pm
Thanks, I saw those last night.
I'm tired of my pipe bender & torch. I'd like a new electric one, but I'd be happy to buy one used if I could save a few dollars.
PostPosted: Thu Jan 31, 2008 9:11 pm
If you want to go a cheaper route, I actually made one out of 2" galvanized pipe and a 120v Mobile Home DRY water heater element. The element was $13 at Ace Hardware and the end cap and pipe flange cost me less than $10. I use the same rehostat to control the temp that I use for my bending blanket. You could also use a router speed controller to control the temp.
PostPosted: Thu Jan 31, 2008 9:30 pm
I have one, PM me
Andy
PostPosted: Thu Jan 31, 2008 11:38 pm
Hi Todd,
Thanks. I already have a fox bender. I need an iron for touchups, etc. I may be visiting my cousin, and would like to get together then. No Idea when. Let me know if you go to Martin for the tour.
PostPosted: Fri Feb 01, 2008 1:09 pm
Hey Ken, that's a cool setup. Does the thingee heat the pipe evenly, or do you have hotter and colder spots?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Feb 01, 2008 2:06 pm
There is about a 6" wide hot spot in the pipe, in the middle of the pipe. It is wide enough to bend anything I have tried to bend so far and the whole thing cost me less than $20. If you try to run it at full heat, it will blow a 15a breaker. Wide open is WAY too hot anyway. About 1/2 throttle is about perfect for bending most woods.
If you buy the element, just make sure it is a 110v model and also that it is for a DRY well. Regular submerged elements wont work as they require water.
PostPosted: Fri Feb 01, 2008 2:27 pm
Ken, do you have a dimmer on that If so, what type?
PostPosted: Fri Feb 01, 2008 2:48 pm
J, I think he said he uses a router speed controller. Same thing used for heating blankets.
PostPosted: Fri Feb 01, 2008 3:24 pm
:oops: My bad, I should have read his post more carefully.
PostPosted: Fri Feb 01, 2008 9:05 pm
if you're making one used with a torch, I heard it recommended that you use a thick walled pipe to avoid hot spots. I suppose that ought to be true of an electric bender too though...
My biggest issue with wanting the ibex, is that it has oblong surfaces. I wound up case hardening (i think) some EIR binding on my smallish thick walled, torch fired pipe. I think I'll enjoy the handwork if I have a descent tool to do it with.
BTW, I have & use a Fox bender for most things (including bindings)
Users browsing this forum: Gary Davis and 23 guests
