It is currently Sun Jul 20, 2025 6:54 pm
 Post subject: Walnut purflings
PostPosted: Tue Feb 05, 2008 8:55 pm
City: Keene
Hey guys, I'm looking for a source for walnut purfling strips, but I keep coming up empty handed. Anybody got any leads? Thanks - justin
 Post subject: Re: Walnut purflings
PostPosted: Tue Feb 05, 2008 9:08 pm
If you just want single lines, buy veneer and trim the strips yourself with a knife. Just be careful that you buy plain wood veneer, and not something with a backing. There are some on ebay now, and there are large veneer suppliers that also would have this.
PostPosted: Tue Feb 05, 2008 9:24 pm
What size strips are you looking for? I may be able to help you out.
PostPosted: Tue Feb 05, 2008 10:03 pm
City: Keene
Hi Ken, I'm looking for strips close to a thickness of .02, .100 wide, and around 32-36 inches long. That would be great if you had some. Thanks - Justin
PostPosted: Tue Feb 05, 2008 10:37 pm
try shane at high mountain tonewoods.
and pick up some tops while your there.
phil
PostPosted: Tue Feb 05, 2008 11:19 pm
Rockler usually has Walnut veneer, in plain wood. Also, Constantines, has lots of plain wood veneer. Of course you would have to thickness sand it to what you want.
PostPosted: Wed Feb 06, 2008 1:37 am
The .1 is no problem, but the .02 is....at least for me. Your best bet would be to look at some veneer as it comes standard thickness at .022 most of the time. You may want to look at www.veneersupplies.com or eBay and see if any of this suits your needs.
purflings are normally around .8 thick and .140 wide. I could do this easily.
Sorry I couldnt help..
PostPosted: Wed Feb 06, 2008 9:58 am
Ken! .8? That's some heavy duty purfling.
PostPosted: Wed Feb 06, 2008 10:05 am
City: Southwick, MA
Are you able to process some scrap strips to the thickness you want? I have A LOT of walnut strips that I just picked up from the woodworking school, and some nice tiger maple as well. PM me if you want some of it...the walnut that is - Bruce Dickey already laid claim to the maple...
Mitch
PostPosted: Wed Feb 06, 2008 5:40 pm
City: Keene
Thanks for the help guys, I think the prudent thing to do would be to buy some veneer and slice it up... That way I'll have enough to last a very long time.
PostPosted: Wed Feb 06, 2008 5:50 pm
:D yeah it is.. I meant .08.... Dang you have a sharp eye Waddy :)
PostPosted: Wed Feb 06, 2008 11:54 pm
First name: Greg
Last Name: Harrington
If you are doing a walnut back and sides, you might have enough to make purfling strips from the edges of the two sides (if not already bent), slice a strip off of each of you desired width and you can thickness this to .04, .06, .10 or whateverf or bindings
Veneers are usually 1/42 = 0.02.
.04 is about two veneer sheets which you are thinking of already. Thoughts on laminating glue? I've used titebond but actually prefer gorrilla type urethane. It seems to stand up to bending heat better. Wrap in wax paper and clamp between flat stock to make a "sandwich" of the whole 6" wide veneer roll and slice strips from this. Wear vinyl or latex gloves, this is gooey messy. You can slice off 1/8" with a band saw or exacto knife. bandsaw is faster but leaves a fuzzy edge. Pull the strip through sandpaper folded in 2 and it cleans up nicely.
Greg
PostPosted: Wed Feb 06, 2008 11:58 pm
How bout a pasta maker for slicing it up? ANyone used this method here?
PostPosted: Thu Feb 07, 2008 1:24 am
no, but I have been thinking the same thing... let me know if it works
Users browsing this forum: Ken Lewis and 9 guests
