It is currently Sat Jul 19, 2025 9:34 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 15, 2008 5:48 pm
Bob, that's a beauty for sure. I hope you didn't have to cut out those pieces, but were able to purchase them? (Man, that would be a lot of tedium.) And were they inlaid into a black mastic?
Bro, many thanks. As you are the more artistic of the Kinnaird bros, I appreciate the kudos no end.
PostPosted: Sat Mar 15, 2008 6:02 pm
Steve, I got the inlays from Andy DePaul... they are hand cut, believe it or not!... and yes, they are in black epoxy.
long
PostPosted: Sat Mar 15, 2008 6:44 pm
Very nice rosette Steve, Glad you did it the hard way, I always though using the "goo method" was cheating anyway. Eat Drink
PostPosted: Sun Mar 16, 2008 9:30 pm
Thanks, Bob. Yeah, those do have a Vietnamese look to 'em. :D
John, thank you for the nod. I really thought about the goo method, but knowing how sloppy I am, I figured that would end up being more work in the long run, what with cleanup, scraping, etc.
PostPosted: Sun Mar 16, 2008 9:54 pm
That's a nice one, alright: the extra space around the shell elements really makes it look classy.
It ought to be possible to make the wood background as a log or logs that fit around the pearl and could be sliced up and stuck in. Suppose you drilled a hole the size of the dot in a piece of wood a couple of inches thick. Plane it off to remove half of the hole. Trim it to length on either side, and bevel the ends off to fit the taper of the diamonds. Slice it up, and put the wood pieces in around the circle. you could trim off the edges to the proper curve after the parts were in. This way you could use something like curly koa as a background, and not be limited to black. It would be tricky making it precise enough to look good, but that's the challenge.
That's what I love about making rosettes: there's so much you can do with the designs.
PostPosted: Sun Mar 16, 2008 10:09 pm
Many thanks, Al! You guys have got me feeling pretty good about the design. Al, your idea is a solid one...I like it. I like the idea of milling into a blank the needed precision, then slicing off segments.
These particular lozenges would be a bit of bother though as the sides are concave. Also, getting all the points to line up would be a challenge. The segment lines plus the circle "guided" the four points of the diamond, but each one had to be fudged. All four points could not hit the described lines. That's the beauty of a black background!
PostPosted: Mon Mar 17, 2008 1:48 am
I like the ball and diamond pattern! Looks very classic!
Good job Steve!
PostPosted: Mon Mar 17, 2008 1:06 pm
Thanks, Billy!
Picture that as a necklace around JJ's pooch?
SK
Users browsing this forum: Dave Rickard and 19 guests
