It is currently Sat Jul 19, 2025 3:10 pm
PostPosted: Tue Jun 03, 2008 4:15 pm
Has anyone here ever convered a PerformaX to hook and loop. If so where did you get the PSA hook tape?
PostPosted: Tue Jun 03, 2008 4:35 pm
Go HERE, see conversion rolls.
PostPosted: Tue Jun 03, 2008 4:43 pm
This is the hook tape?
PostPosted: Tue Jun 03, 2008 4:50 pm
I'm pretty sure, but go to this page and call the 877 number and they can clarify.
PostPosted: Tue Jun 03, 2008 7:39 pm
Michael Grizzly tools carries what your looking for.
PostPosted: Wed Jun 04, 2008 8:35 am
Thanks guys [:Y:]
One more question for anyone that is working with a hook and loop system on their dum sander.
I would assume that heat could be an issue. So I assume that very light cuts are required or am I over thinking the heat issue?
PostPosted: Wed Jun 04, 2008 8:50 am
MichaelP wrote:
Thanks guys [:Y:]
Actually it's less of a heat issue. The velcro proivdes a cushion so better air flow. Tension rollers may need to be adjusted due to the extra thickness. This stuff really sticks to a clean drum so remove the backing on as you unroll.
PostPosted: Wed Jun 04, 2008 11:41 am
I have heard that hook and loop takes away from the accuracy of a thickness sander due to the compressibility.
PostPosted: Wed Jun 04, 2008 1:04 pm
Good thought line Barry. but here is a question on that train of though. If the compression is equal why would this be the case? Anyone have experiance or thoughts on this?
PostPosted: Wed Jun 04, 2008 1:40 pm
I had been wondering the same thing. My guess as to where the accuracy would suffer would be in the lower tollerences of the manufacturing process for hook and loop material. I have measured variance of around .002 in non-hook and loop Performax paper. With the compressability issue/possibility I didn't want to be the one to try this out...... but I would be very interested in what results.
Any time you can add to drum cooling that is a good thing.
PostPosted: Wed Jun 04, 2008 6:51 pm
I still havent found a sandpaper for my 16/32 that I am happy with. If this works out for you, please let us know?
Users browsing this forum: rbuddy and 21 guests
