It is currently Sat Jul 19, 2025 12:53 pm
PostPosted: Sat Jun 07, 2008 12:33 pm
First name: David
Last Name: LaPlante
Having just retired from 34 years at the New York State Museum I'm taking a bit of "vacation" before I get down to building full time and decided to get back to a Torres replica project that I started a while ago.
The Torres SE 151A seen in the later editions of Jose' Romanillos' book is one which I discovered here in Albany around 1988. The guitar was later sold by its owners (the granddaughter of a woman who had emigrated from Almeria in Spain during the 30's) at Christies in London for around $20,000. Fortunately I was able (after making a new peg and a few other minor repairs) to keep the guitar and document it for several months.
Here is the main drawing of the top bracing with notes.
As well as written notes and dimensions etc...
The braced top being glued to the neck
Clamping the foot and neck block
The 3-piece cypress back and sides with linings being installed
The linings are spruce as on the original and are continuous kerfed both top and back
The peghead with the preliminary shaping complete
This guitar is quite small by today's standards and has a 610 mm scale. It is quite similar to the small Torres guitar SE 117 featured in Courtnalls book which we saw in Spain at the shop of Jose' Romanillos this past summer.
Though there are other Torres guitars which perhaps would be a better musical choice to copy, having had this one in my hands for a period of time and detailed notes and photos, I felt it is my best opportunity to make a replica closer to the character of a genuine Torres than would be otherwise possible.
Last edited by David LaPlante on Sun Jun 08, 2008 12:53 pm, edited 1 time in total.
PostPosted: Sat Jun 07, 2008 2:40 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Great info & pics Dave!!
Your dedication and love of these instruments makes you a valued
source to all guitarmakers ! [:Y:]
Pencil lines -instead of saw marks??
keep up the great work !!!!
Your retiring!!!!!!
Holy s*** -now you'll really get some time to make those beautiful guitars of yours!!!!!
Mike Collins
PostPosted: Sat Jun 07, 2008 3:20 pm
Dave! I'm jealous! I just have no guts, or experience. gaah The plan looks great, as does the progress on the instrument. Can't wait to see this one finished, after your last venture in a Torres copy.
PostPosted: Sun Jun 08, 2008 8:21 am
Country: Romania
WAY Cool!! Can you describe the sound of this small type of guitar? I imagine they lack bass depth but sound sweet with good separation and are well suited for early, very traditional and uncomplicated spanish/flamenco music. I plan to build one of these sometime as well.
Build log
PostPosted: Sun Jun 08, 2008 11:39 am
Dave, Great project, please keep posting pictures as you progress, I would really like to see this one as it comes along towards completion.
PostPosted: Sun Jun 08, 2008 1:28 pm
First name: David
Last Name: LaPlante
Continuing progress on the Torres SE 151A Replica project:
The top with rear block and neck now attached and ready for the sides to be fit.
Linings are now attached to the sides and ready to be fit.
I'm using a cardboard insert between the small workboard (solera) and the top in order to add 2mm of "lift" to the neck as well as accomodate the doming of the top created when the braces were glued using my regular full size contoured solera.
I'll be putting the guitar together on the work board using the "free assembly" technique where the sides are assembled onto the top and neck using a pencil line tracing of the body shape under the top as a guide. Here is where hot pipe bending the sides can be a big advantage in that there is less "spring back" to wrestle with as you go.
In addition to the linings being removed at the brace locations, the braces themselves are trimmed back to allow the thickness of the sides plus an additional mm or so.
The side are fitted, then glue applied and clamped...I'm using fish glue on this one as it will give me extra "open" time.
In clamping the sides are carefully aligned with the pencil line on the top.
The process is completed on the other side, here both sides are now in position and clamped.....no, those aren't the big quick grips, they are the regular small ones, it shows just how diminutive this guitar is!
PostPosted: Sun Jun 08, 2008 1:54 pm
First name: David
Last Name: LaPlante
Now it's time to install the "rib blocks" under the braces. In Torres' design the harmonic bars are parallel and left square at the the ends to take these small supports.
The block has been "skewered" on to a sharp tool and glue applied. Fish glue has a very high tack and is perfect for this application.
You can see the "toothing plane" marks I've added as on the original.
The rib block in place. Both harmonic bars on top will get these as well as the back braces.
Torres is known to have followed the construction technique of back braces being installed into the body prior to the back being glued on. Though I have done this technique, the lack of a wood back reinforcement strip on this guitar (which is quite helpful in registering the back when glueing) would make fitting it in this way quite tricky.
Here are the back braces being glued, I'll leave the squeeze out as is to simulate the results of Torres' technique and fit it up normally adding the rib blocks beforehand.
Notice the handwritten 19th century music paper which I've replicated as an accurate facsimilie of what was used to line this guitar and many other 19th century Spanish guitars.
PostPosted: Sun Jun 08, 2008 2:09 pm
Last Name: Collins
City: Argyle
State: New York
Nice Dave-Nice! [:Y:]
What rosette design did you us on this one?
Mike Collins
PostPosted: Sun Jun 08, 2008 2:26 pm
First name: David
Last Name: LaPlante
Here it is Mike, it's a replica of the original with black and white
lines, rosewood and one green circle(?!).
Also the top is made up of three pieces of German spruce with the join running at a diagonal and the third piece on the lower treble bout.
PostPosted: Sun Jun 08, 2008 3:18 pm
Country: Romania
Is the small solera completely flat? In that case, the carboard seems not to be helping the neck lift up; but on the contrary.
Build log
PostPosted: Sun Jun 08, 2008 3:51 pm
First name: David
Last Name: LaPlante
Yes, the solera is flat and the cardboard extends only under the top to the point of the neck/top join. The neck is clamped at the nut end directly onto the surface of the solera (upside down) giving it a "lift" (around 2mm) equal to the cardboard's thickness.
PostPosted: Sun Jun 08, 2008 4:15 pm
Country: Romania
Big duuh. I didn't realize the white part is thick. I just thought it is plain white paper duh
Build log
PostPosted: Sun Jun 08, 2008 4:21 pm
Last Name: Collins
City: Argyle
State: New York
Again -great work !!
Your dedication to making these "Torres" models as close to the originals is just incredible!!!!!!!
You may have motivated many guitarmakers to research & build some
historicly important instruments!!!!
You should be proud ! [:Y:]
Mike Collins
PostPosted: Sun Jun 08, 2008 11:44 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Oh man! You close your eyes for a day or so and look what shows up!
Good job David. I've got a few SE117's in the works, but not nearly so authentic as yours. Maybe one day I'll be able to surrender myself completely to the old Don...
http://redrivercanoe.ca/
PostPosted: Mon Jun 09, 2008 4:28 am
David, that is fascinating, as you might know I'm almost fanatical about Torres and building with as much historical accuracy as possible. I like the toothing plane marks!
What's the origin point of the kite?
PostPosted: Mon Jun 09, 2008 4:57 am
Country: Romania
To me it looks the same as SE117, at about the fret before the last - 79mm in Romanillos book, but David's braces seem to be more spread out. In 117 they do not seem to interfere with the linings.
Build log
PostPosted: Mon Jun 09, 2008 8:06 am
First name: David
Last Name: LaPlante
Colin, Alex,
The apex of the braces seems to be at around the 16th fret
(of 18 total).
I made at least two drawings of the top (almost 20 years ago) when the guitar was in the shop having made the second to correct some innaccuracies as to brace thickness. These don't quite agree as to the fan apex but are quite in accord that the ends of the outermost fans come to within about 8mm of the outside of the lower bout.
As you know, SE 117 was heavily worked over before Jose' restored it and SE 151A was made in the last year of Torres' life and shows some very uneven workmanship as well as perhaps other another hand involved in its construction. I'm not surpised that there is some variance between them.
Also too as a perspective, this is really a tiny guitar (only 67-72 mm in depth) and I remember being relieved that the bridge wasn't loose as I couldn't get my hand inside to place a caul, thus it was difficult to measure. I seem to recall that I placed a light inside to record the brace positions.
At any rate I'm enjoying the project and will contunue to post my progress.
Best!
PostPosted: Mon Jun 09, 2008 9:10 am
Country: Romania
Here is something perhaps relevant:
Another tiny cypress guitar, 620 mm scale, made around 1900 by Manuel Ramirez who built in the Torres style. The page has 2 sound clips and they sound quite charming.
Build log
PostPosted: Mon Jun 09, 2008 1:41 pm
First name: David
Last Name: LaPlante
actually, This one is extremely similar to the one I'm replicating....if you read the Bio you can see that Beltran may actually have had some participation in the construction of SE 151A.
http://www.zavaletas-guitarras.com/file ... eltran.htm
PostPosted: Wed Jun 11, 2008 10:13 am
First name: David
Last Name: LaPlante
Here are some more progress pics.
Since the original frets on this guitar are the bar type, I'm cutting the slots on my Proxxon saw using a blade with the kerf reduced to about .050".
The back on:
As I mentioned, this guitar is quite small, here it is next to my replica of the Torres SE 114.
The back on this guitar is the cypress 3-piece type seen on many of Torres' simpler guitars.
Detail
Next, on to the bindings!
PostPosted: Wed Jun 11, 2008 2:52 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Nice! Looking forward to hearing about the final product.
PostPosted: Wed Jun 11, 2008 4:28 pm
Coming on well David, this will make a wonderful little fireside guitar.
I'm interested in your SE114, it's on my list of guitars to make. As you may know I'm a bit of a Tarrega fanatic, having recorded a number of his pieces, and I built my La lena guitar especially to capture the earlier Tarrega sound. I now need to build an SE114, do you know where I can get drawings of this? I could probably work it out from the measurements in Romanillos.
PostPosted: Wed Jun 11, 2008 4:57 pm
First name: David
Last Name: LaPlante
Yes, The Guild of American Luthiers (GAL) now offers an excellent plan of SE 114 by Jeffrey Elliott drawn when he restored the guitar for the owner Sheldon Urlik. It's the one I used to make the guitar in the photos.
It's very detailed and has a wealth of excellent info.
Highly recommended!
PostPosted: Thu Jun 12, 2008 2:29 am
Highly recommended!
Thanks David, being on this side of the pond I tend to forget GAL!
PostPosted: Thu Jun 12, 2008 3:17 pm
David, really exemplary work. I hope to see more of your guitars this summer in
San Francisco. Thanks for this detailed post,it's great. Helps me realize how much
more I need to learn! Very nice stuff.
Best
Bruce
Bruce Herrmann
"What lies behind us and what lies before us are tiny matters compared to what lies within us."
Users browsing this forum: J De Rocher, Michaeldc and 23 guests
