It is currently Sat Jul 19, 2025 3:58 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 27, 2008 6:50 pm
Dave Stewart wrote:
Just curious....is there some benefit to doing the purfling step last??
(I've only ever done it as the first step - after flush trimming - & have had no issues)
Maybe but I don't know for sure. But it seems to me that any time you have an opportunity to remove less wood in a single pass the risk would be lower - all other things the same of course such as climb cuts, sharp bit, etc.
PostPosted: Sat Jun 28, 2008 3:22 am
Last Name: O'Melia
City: Huntsville
State: Alabama
fmorelli wrote:
I did the group buy purchase about 4 years ago on the Luthier Forum (Mario's place) for the bit set. I don't recall who did it, though.
For my binding jig, I've gone with the Dewalt laminate trimmer with independent bearing guide. No fuss on bearing falling off, burning up, et cetera. Downside is that you have to set up each time. On the other hand, you're free to buy top quality spiral bits (e.g. CMT) which serve the purpose well.
Filippo
How does this work?
PostPosted: Sat Jun 28, 2008 10:30 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Ok, Iget the lazy suzan part, but where do you get that bearing fixture? Are there drawings and specifications for that base?
PostPosted: Sat Jun 28, 2008 1:01 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Is this the part I will need?
http://www.amazon.com/Bosch-PR003-Rolle ... JK5AFSXEH5
PostPosted: Sat Jun 28, 2008 10:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Filippo,
Yes, I finally figured that out. I am ordering the one for the Bosch. My only question now is regarding the proper bit (spiral down??) size and all of that.
PostPosted: Sun Jun 29, 2008 10:32 am
slackkey_mike wrote:
Filippo,
Mike, I've got the Bosch & guide you linked from Amazon. Works pretty well for me. I've had to buy a couple of different sized bits for routing different depths because the guide only adjusts so much. The upside is that you can make really fine adjustments to the edge guide. I think it's a different method than what's typically done, but I don't see why it can't work.
Flori
PostPosted: Sun Jun 29, 2008 4:45 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I can vouch for the StewMac bit/bearing set with the bushing to offset the bearing. I did the binding/purfling on my first guitar just recently using their set (on my Williams-derivative jig). You cut the binding channel first, then put the little bushing on before the bearing and then cut the purfling channel - it works great! 8-)
Cheers,
Dave F.
Cambrian Guitars
Users browsing this forum: Dave Rickard and 31 guests
