It is currently Mon Jul 07, 2025 3:40 pm
 Post subject: Doug fir as top wood?
PostPosted: Mon Jul 07, 2008 8:43 pm
I would like your opinion. I was able to snafu some quarter sawn doug fir from some 50 year old bleachers they tossed at work. Here are a couple of pic. Have you ever used doug fir as a top wood? Would you mess with the wood shown here?
Mark Ewing
Columbus Ohio
"Trees are an important and precious thing. We should build good things with them. Building good guitars with heart are the best use for them." K. Yairi.
PostPosted: Mon Jul 07, 2008 8:58 pm
The few things I have heard have been positive. I have some very old Doug Fir around that I have been wanting to try so I'm looking forward to the replys from others.
Mark
Wisdom is justified by her children
PostPosted: Mon Jul 07, 2008 9:32 pm
grab it man! David Freeman, had some nice sounding doug fir at the Gal gathering ! he was lucky enough to find some big enough for a one piece top! Jody
PostPosted: Tue Jul 08, 2008 12:24 am
First name: Heath
Last Name: Blair
City: Visalia
how does it sound when you tap it?
sweat the small stuff.
PostPosted: Tue Jul 08, 2008 1:20 am
I am also very interested in this wood for carving small archtop guitar plates (L-1 size).
Tom Krebs
PostPosted: Tue Jul 08, 2008 4:01 am
David Freeman was one of the lecturers at the convention , I didnt get to tap the top, but the guitar sounded good when played! Besides , you cannot talk in general terms like that ,some spruce, sounds good when tapped , some does not , even from the same tree,.The wood definatly warrant consideration! Jody
PostPosted: Tue Jul 08, 2008 6:09 am
Douglas Fir has definitely been used as a top wood. If it has a good stiffness to weight ratio (and you're not trying to sell the guitar) I would go ahead. I have a set in my stash that I plan to use in the future. There is a Luthier and tonewood dealer, Larry Stamm who sells Fir, I have never seen him on this forum but you might look up his website for a little info and perhaps ask how he approaches it.
David White, Toronto
PostPosted: Tue Jul 08, 2008 9:13 am
A high-end classical maker I know used to offer fir as an option. While he now only uses euro spruce for it's superior projection qualities, he has built many fine instruments with fir. Again, it will likely project less than a spruce top. I'd give it a try if I had some lying around.
-Clint Beacock
PostPosted: Tue Jul 08, 2008 11:16 am
Some pieces of Doug Fir can have a lot of pitch that keeps oozing which can be a pain, but only some. Genrally Doug is supposed to be stiffer and heavier than Sitka, but I have found there are many examples that overlap Sitka(which really means it is "in the ballpark" with much of the spruce out there, and I have even found Doug Fir that was far weaker than average Englemann). Doug Fir, Hemlock, and Sitka all are used as a structural timber in the Northwest. I have found bits of each that fit the bill for weight and stiffness, and ring like a bell. To me good wood is good wood. If you are selling a guitar, people often look for species X irregardless of the actual piece of wood. So unless the customers perception is favorable to Doug Fir, you may need to put perception over function. Offering less known woods as an "upgrade" is pretty smart as many view price follows quality or performance.
Since you have access to the wood, and it has potential, saw some up and see what you get. Shoot even if it does not have favor with customers today, you can use it for personal guitars, and down the road when it is a commonly used wood you will have great seasoned stock to offer. You can never have too much quality seasoning wood on the shelf.
Rich
PostPosted: Tue Jul 08, 2008 11:33 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I think your use of the term "snafu" was amusing!
Let us know how it works out.. Looks like a tight grain.
PostPosted: Tue Jul 08, 2008 12:50 pm
I thought snafu was an acronym for "situation normal, all f***ed up"
PostPosted: Tue Jul 08, 2008 1:29 pm
If this is the same wood they used to use for stair treads...I have tried it for archtop carving. It is really freak'n hard to carve. I have a violin top in my car right now that we started a long time ago and gave up on it due to how hard it was to work with. I would think as a flattop...top, it would be very stiff and would probably work out ok. The stuff I have at the shop is very straight grained and looks very much like spruce from the front. I thougth it was going to be perfect for the fiddle, but it is really dense to carve.
I am bring that top over to J Resslers tonight along with some other carved tops just to stimulate the conversation of tone-tapping etc.
Joe
Joe
PostPosted: Tue Jul 08, 2008 4:53 pm
Your interpretation of the an-acronym is correct. It is military phraseology, but it also is used north of the border to denote snagging something just in case it is needed. It works.
Mark Ewing
Columbus Ohio
PostPosted: Tue Jul 08, 2008 4:59 pm
I have a variety of different qualities in this wood. Different weight, different grain texture (tight to course). What top thickness would you be shooting for; .115-125 or so, thick thin? What determines that for you?
Mark Ewing
Columbus Ohio
PostPosted: Tue Jul 08, 2008 7:55 pm
I believe that Tim McKnight has used it quite successfully. Maybe he'll drop in on us and give you his impressions. I have a couple sets from a good friend that I'm looking forward to using some day.
PostPosted: Tue Jul 08, 2008 11:50 pm
I used 6/4 vertical grain doug fir for my bench top. Works great.
As an older guy, I have only so many guitars left in me. That is to say, no time for dinking around with something out on the fringes, as douglas fir is. (Seen many out there? Seen ANY?) I'll spend my time with the well proven spruces and cedar. But my goal is a superior sounding instrument; your goal may be something else.
Give it a try, and let us know how it works out.
Larry
