It is currently Wed Jul 23, 2025 2:31 pm
PostPosted: Mon Sep 01, 2008 11:20 am
First name: paul
Last Name: harrell
City: Pittsboro
After several years of using varnish I am about to throw in the towel - I love the look of varnish but it just takes too many hours.
The question I have is where to leave the guitars while the lacquer is curing. My shop is very tight and the outgassing would probably kill me and if I put them in the house my wife would kill me. How important is temperature and humidity control during this time? How long after spraying is the smell and/or toxicity a problem. Any solutions would be appreciated.
Thanks, Paul
PostPosted: Mon Sep 01, 2008 12:27 pm
Paul, I don't know where to tell you to keep the guitar for curing other than a well ventilated warm area, and definitely not in your house. But I have a question about the varnish, won't japan drier speed it up?
PostPosted: Mon Sep 01, 2008 1:13 pm
First name: paul
Last Name: harrell
City: Pittsboro
It's not the drying time that is the problem - It's having to completely sand the guitar between every coat. And you have to sand the final coat very carefully and to a pretty high grit, because sanding scratches don't buff out nearly as easily as they do with lacquer. And if you sand or buff through a coat you get a witness line that cannot be fixed. You just have to do another coat on the entire surface (sides, back or top), there is no touching up.
Peace, Paul
PostPosted: Mon Sep 01, 2008 1:40 pm
Sounds like you'll have to leave it in your shop. Make a little cabinet like this,
and seal the doors. Add a little computer fan to suck air through the cabinet and out of your shop.
PostPosted: Mon Sep 01, 2008 7:55 pm
First name: paul
Last Name: harrell
City: Pittsboro
Thanks Rod - That looks like a good solution. Thanks, Paul
PostPosted: Tue Sep 02, 2008 9:45 am
Paul, since you're thinking about switching finishes anyway, have you thought about trying Tru Oil? The more I use it the more I like it. It's easy to apply and the end result is a super thin finish that is easy to repair and can be buffed to a fairly high sheen or left as a nice soft satin. I've used it on my last two builds and think that it will be my first choice going forward.
PostPosted: Tue Sep 02, 2008 4:32 pm
I would like to second the tru-oil idea although I must admit it is based on little experience. I haven't tried it up until now because I had assumed that you couldn't get a gloss finish. However, after seeing this guitar:
viewtopic.php?f=10101&t=17078&hilit=+true+oil+
I decided it was time to try it myself. I wiped on 14 thin coats on to a test board and let it sit for three weeks. After that I was able to sand and buff it out to a finish as glossy as anything I've been able to do with Deft, KTM-9 and French polished shellac. And it was the easiest to apply. So I will be using it on the guitar I just started.
Users browsing this forum: rbuddy, TimAllen and 15 guests
