It is currently Sun Jul 27, 2025 10:54 pm
 Post subject: Re: Leveling the Sides
PostPosted: Sat Sep 27, 2008 8:43 am
A little tip I got from Hesh, who in turn got it from Mario (really, who has better tips than Grumpy?)...
Instead of cutting the overhang flush to the sides, you can actually take it in a bit further. I know you need to be properly tooled up for this, but any kind of jig where you can select the depth of cut would do. I guess you could always use bearing sets and use a size that would still give you enough leeway with the binding thickness...
This way, you don't have to contend with sanding the top or back plates' endgrain.
PostPosted: Sat Sep 27, 2008 8:53 am
This is Great! Seeing the pictures makes it easier to understand. Thanks Todd!
Is there a reason why you use Norton 3M or 3X?
David
PostPosted: Sat Sep 27, 2008 10:50 am
Todd, any chance of a clear view of your vise? Is that thick foam on the jaws?
Thank you.
Dan
http://www.acme-archtops.com
PostPosted: Sat Sep 27, 2008 11:11 am
Dan, I can help you out,
Here's a picture of the guitar trojy (trogy, trogi troji) that I made and some plans I drew up in order to make one.
GuitarTroji.pdf
Todd has a better screw thread and handle than mine I think and here's a link to a recent thread on the troji handle.
PostPosted: Sat Sep 27, 2008 12:17 pm
I scrape.
PostPosted: Sat Sep 27, 2008 1:58 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
use scraper and make sure edge to edge no gaps,bumps, etc.
PostPosted: Sat Sep 27, 2008 2:22 pm
Rod, thank you so much!
Dan
PostPosted: Sat Sep 27, 2008 4:32 pm
Scraper here as well. My philosophy is always use an edge tool in preference to abrasives.
