So Tracy, if I understand your question/problem right, your worried about the gap at the front of the body between the underside of the fretboard and the top due to the climbing of the radius you have put in the rims and now transfered to the top once glued on. So, I layed this out on cad and the average distance from the front of the sound hole to the front of the body is 3.8-4" respectivly. If you have a 28' (336") radius sanded into that top, the distance between the curve of the radius and a straight line from the front of the body to the top of the sound hole measure out to 0.005" which I am sure will close up once you install the neck so no gap should be there, let alone visible. You could wipe your rough fingers inbetween the two points to bring that amount of wood down. You Don't need a fancy jig to get this area flat, just a 6-8" length of hardwood run over the jointer with sandpaper will do.
If that is the case, won't the end of the FB extension hit wood near the soundhole and the neck joint should have a gap. I know a lot of you sand this area flat with one of those fancy jigs, but it just looks like a huge gap from the middle of the side to the head block. Should this not be very much of a gap?
if you rock the fb extension over the radius from one point to the other, there should be a maximum gap of 0.010" hardly much if you ask me. Just make sure that the top is flat (relative to the radius of course) when you glue down the fb extension.
So, as far as I can see, it's just easier to sand that area flat and be done with it.
PS, how do you guys get that fancy board and quote from a previous post into your post??
Guitars, no problem, forum editing that's my big problem.
Rod True38604.885625
My Facebook Guitar Page"There's really no wrong way, as long as the results are what's desired." Charles Fox
