It is currently Tue Aug 05, 2025 5:55 am
 Post subject: Fret End Angle?
PostPosted: Sat May 16, 2009 10:44 am
I've been using 35 degrees for my ukes, but think this is too much for guitars. What is the recommended angles for a steel string and nylon string guitars? Thanks
A higher purpose for wood.
Rich Smith
Issaquah, WA
 Post subject: Re: Fret End Angle?
PostPosted: Sat May 16, 2009 11:19 am
I use a 30 degree
PostPosted: Sat May 16, 2009 11:30 am
Country: Romania
For nylon don't be too enthusiastic about filling the end, since the high e slips off very easily.
Build log
PostPosted: Sat May 16, 2009 12:50 pm
On that subject not to change subject but do you all put your strings at a certain distance from the edge? I've been putting mine where it makes playing the easiest for me. I put my 6th. low E edge not center to where it is pretty much even with the bevel of the fret. I like to use my thumb when bar chording certain chords and my hands aren't but med. sized and the closer I can get the string to the edge the easier it is to catch the string with my thumb. The high E or first is abot an 1/8" to center and sometime a little less . I locate the Es on my unslotted and unglued nut and mark each side of the string with a half pencil and then slot them and use StewMac string spacing rule to locate the others. Pretty much the same for the saddle. Bevel at 35 degrees.
PostPosted: Sat May 16, 2009 1:37 pm
Chris, I go 1/8" on the low E string and 3/32" on the high E string.
Richardo, I don't think there is a 'standard' really, again it's about player comfort and playability.
PostPosted: Sat May 16, 2009 8:48 pm
15 degrees is something to shoot for.
PostPosted: Sun May 17, 2009 6:37 am
First name: Matthew
Last Name: Rust
City: Columbus
Zip/Postal Code: 47201
This is exactly how I screwed up my first fret board. Luckily the board wasn't glued to the neck yet... When Making the jig to file the ends, I went by my table saw's gauge. According to it, the blade at 90 degrees was "0", so when I cut at "30", it was actually somewhere near 60 degrees... Needless to say, those ends were out of control. When I re did them, I emulated one of my guitars and that ended up being 35-40 degrees. The nut width is 1 7/8", so I have plenty of room.
Don't confront me with my failures--I have not forgotten them.
PostPosted: Sun May 17, 2009 1:43 pm
Boy, opinions range all over the map! Lets hear from some more classical guitar builders.
Rich Smith
Issaquah, WA
