It is currently Fri Jun 13, 2025 9:37 am
PostPosted: Wed Sep 09, 2009 12:21 pm
I've used the McFaddens Rosewood sealer and found the visual depth to be lacking. How is Isolante?
Is Chemcraft (now Akzo Nobel) a PIA to deal with? It sure seems like it from this end.
PostPosted: Wed Sep 09, 2009 4:29 pm
Do you mean the clarity of the sealer? I have found the rosewood sealer to be extremely transparent and since so little is applied I don't understand how depth plays into this?
jw ( o)===:::
PostPosted: Wed Sep 09, 2009 8:33 pm
First name: Erik
Last Name: Hauri
State: Maryland
I think Sheldon is talking about chatoyance - or how 3D the grain appears when you apply the sealer.
The member formerly known as erikbojerik....
PostPosted: Wed Sep 09, 2009 9:15 pm
What he said.
PostPosted: Wed Sep 09, 2009 11:34 pm
Ohhhhh,, Magic Sealer?? idunno laughing6-hehe
Seriously, if the wood has any pop to it at all, the sealer will "wet" it enough to see what's going on in the grain. I would have to think that Isolante and Rosewood Sealer appear very similar once sprayed. The big advantage with Isolante is no scuffing and not having to wait overnight.
jw ( o)===:::
PostPosted: Thu Sep 10, 2009 10:09 am
I haven't found that to be the case. The wash coat can make or break the depth (chatoyance - I've never liked that word) of the top coats.
To me, urethane wash coats have always looked like they lack depth. I haven't played with over-reducing which might be one solution, but might also cause solvent popping issues.
That's "Magic" enough for me, which is why I'm curious about it. ;)
PostPosted: Thu Sep 10, 2009 1:10 pm
That's "Magic" enough for me, which is why I'm curious about it. ;)[/quote]
Me too Sheldon, I have just been afraid to mix products (McF's-Chemcraft) Funny you mention over reduction. I actually under reduce the Rosewood sealer and only apply one coat. Could be why I haven't noticed the sealer distorting the image.
jw ( o)===:::
PostPosted: Wed Sep 23, 2009 8:21 pm
First name: Luc
Last Name: Regnier
Hi Sheldon,
Chemcraft was bought out by Akzo about two years ago.
Regards - Luc
PostPosted: Thu Sep 24, 2009 3:06 am
Thanks Luc.
I called up Akzo a few weeks ago. I haven't heard back from them. In the mean time, I found a company that's relatively close that will custom blend PE to my specs. I'm testing a galon right now.
PostPosted: Fri Sep 25, 2009 3:05 am
Last Name: Garrish
Ask Mike Collins (the Selmer Mike Collins) about it: he uses the Chemcraft UV system end to end.
Bob Garrish
