It is currently Sun Nov 24, 2024 10:39 am
PostPosted: Mon Nov 16, 2009 12:58 pm
Last Name: Lembo
Hi everyone.
Any pros or cons when using a ball mill or corner radius mill for FB side down neck shaft and heel carving? Any preferences?
I can accommodate a 5/8" mill shaft, so I'm not too concerned about length.
I seem to remember some discussion regarding zero speed at the center of a ball mill being an issue for arched plate carving more compression/burnishing than cutting - is this an issue on mahogany?
Thanks!
Anthony
Anthony J. Lembo
Lembo Custom Guitars - www.Lemboguitars.com
PostPosted: Mon Nov 16, 2009 4:35 pm
Last Name: Garrish
A bullnose can't cut a concave surface without leaving a flat on the bottom, but that's the only reason you strictly couldn't use one for certain surfaces. A bullnose of a certain diameter is going to have a sharper corner radius than a ball of the same diameter, which is a strike against, and that means more passes to get the same smoothness.
While there is a burnishing in the center of a cut with a ball, there's very little material thickness being compressed as the cutting edges ahead of the center already take most of the material off before the center reaches a given point.
Bob Garrish
PostPosted: Mon Nov 16, 2009 9:10 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Ball mill are the tool of choice pretty much everywhere I have seen CNC neck carving.
As usual, I'm with Bob on this..!
Trev
http://www.PeakeGuitars.com
Last Name: Lembo
That makes sense. Thanks for your help Bob and Trev!
Constantly second guessing,
Anthony
Anthony J. Lembo
PostPosted: Thu Nov 19, 2009 12:28 pm
City: Escondido
Zip/Postal Code: 92029
I hate to sound ignorant, but what is the difference between bull nose and ball?
PostPosted: Thu Nov 19, 2009 2:28 pm
rlrhett,
Look at these:
http://www.mcmaster.com/#end-mills/=4ko7um
would be an example of a "ball" endmill.
http://www.mcmaster.com/#end-mills/=4ko8gq
would be an example of "bull" nosed endmill.
while these are geared mostly towards metal cutting the concept is the same.
PostPosted: Thu Nov 19, 2009 2:38 pm
ok, well those links don't seem to work well.
So a ball endmill or cutter has a ball on its end that when it's cutting will produce a half round channel equal to its diameter. ie: 1/2 diameter -1/2 round channel, and a bull nosed cutter or endmill has a specific radius to it's end that is less then full round. When cutting it will produce a square channel with filleted corners. The advantage is that the ball cutter will profile a complex surface with 180 degrees of tangency to that surface.
here's some pics:
http://images.google.com/imgres?imgurl= ... n%26sa%3DX
and...
http://www.made-in-china.com/image/2f0j ... M-010-.jpg
hope all this helped [:Y:]
