It is currently Sat Aug 02, 2025 9:56 am
PostPosted: Wed Nov 16, 2005 12:18 pm
So I am building my second guitar which has an Autumn theme. However on my first guitar I used a pre-made bridge. So this is my first bridge. I made it in Zircote to march the back & sides. The oak leaves tie into the fretboard/headstock inlay. Does this look OK or is it "over the top"
PostPosted: Wed Nov 16, 2005 12:31 pm
Bill I think it looks great.
PostPosted: Wed Nov 16, 2005 12:47 pm
I like the inlays.
PostPosted: Wed Nov 16, 2005 1:03 pm
BEAUTIFUL BILL...
WHAT KIND OF WOOD IS THE INLAY LEAVES MADE OF?
WALTER
PostPosted: Wed Nov 16, 2005 1:06 pm
[QUOTE=WalterK] BEAUTIFUL BILL...
WALTER [/QUOTE]
The leaves in the bridge are Koa.
PostPosted: Wed Nov 16, 2005 1:26 pm
Very impressive...your work is outstanding.
PostPosted: Wed Nov 16, 2005 2:10 pm
Really tasteful. I like it.
PostPosted: Wed Nov 16, 2005 2:13 pm
Very nice bridge design and execution Bill. Some of you new to guitar building guys are starting out years ahead of where I started. Very nice
[QUOTE=Bill Greene] No GAS. No WAS. Suffering from TAS though.[/QUOTE]
Bill Greene, That happens to us all so don't feel alone. If the wood guy doesn't get you the tool guy will.John How38672.9280787037
PostPosted: Wed Nov 16, 2005 2:45 pm
I like them too. Why not inlay your pins with Koa dots?
Or, better yet, turn your own Koa pins!
That would highlight the leaves beautifully.
PostPosted: Wed Nov 16, 2005 11:35 pm
Very pretty Bill! And the top, boy is that a nice top!
PostPosted: Wed Nov 16, 2005 11:58 pm
Hey Bill,
nice work. The only reason you could say it was over the top, is because
it's glued "over the top." As inlay goes it's actually fairly conservative and
is quite nice. The only problem with inlay is -- man, does it add to the
build time (at least for me it does). You may be new to guitar building,
but it's clear you're not new to working wood. Again, nice work.
Craig
PostPosted: Thu Nov 17, 2005 12:36 am
First name: Tom
Last Name: Dowey
City: Sudbury
State: Massachusetts
Zip/Postal Code: 01776
Very, very nice. Not over the top at all. Outstanding work and very inspiring. Way Cooool..
PostPosted: Thu Nov 17, 2005 12:59 am
I think that is really beautiful.
PostPosted: Thu Nov 17, 2005 1:40 am
[QUOTE=LanceK] Very pretty Bill! And the top, boy is that a nice top![/QUOTE]
Yes the top is a fantastic piece of Spruce...courtesy of Steve at Colonial Tonewoods. He also supplied the amazing Zircote. I couldn't be happier with the wood!
PostPosted: Thu Nov 17, 2005 2:06 am
I don't think it is over the top in it self. Your inlay looks very nice. The big question is how does the bridge go with the rest of your design?   You say you are working with an autumn theme, so I'm assuming there will be more leaves and such other places, but that should only be "icing on the cake".   Do the curves and the points have other references in your design?
I think a key to good design is treating the object as a whole, where everything from the big lines to the smallest details share common themes and interact visually. If not your bridge could end up as one of many objects that look nice by themselves but fight for attention and take away form the design as a whole.
I'm not implying that this is what you are doing, but the more attention you are drawing to your bridge through its shape, the more demanding it will be to create similar shapes other places. If you can pull it off you could have a winner, if not it will just look busy.
PostPosted: Thu Nov 17, 2005 2:14 am
yes the curve of the bridge is made to compliment the curve at the top of the headstock and the finish curve at the termination of the fretboard. The leaves are the same leaf design as is in the fretboard.
The points at the ends of the bridge are also an exagerated form of the side to top of the headstock intersection.
I'll post some overall photos when I get a chance.
PostPosted: Thu Nov 17, 2005 3:05 am
Looks great Bill...Definitely need some koa pins there to keep the theme.
PostPosted: Thu Nov 17, 2005 4:20 pm
Bill that's just Beautiful! I think it's perfect!
PostPosted: Thu Nov 17, 2005 6:51 pm
Very Beautiful Work. Let's see some more.
PostPosted: Mon Nov 21, 2005 5:55 am
First name: R.W. "Rollo"
Last Name: Scheurenbrand
Great look to your bridge, Bill.
What is your sequence for inlaying the bridge.Do you inlay the rough bridge blank first, or do you shape it, then inlay? What sort of holding device do you use while you route the pattern? What is the thickness of the wood veneer?
Thanks Bill        Rollo38677.5816435185
R.W. '' Rollo'' Scheurenbrand
http://www.koaguitars.com
PostPosted: Mon Nov 21, 2005 7:26 am
[QUOTE=Rollo] Great look to your bridge, Bill.
Thanks Bill        [/QUOTE]
Most of the shaping is done before the inlay. Other wise I would need to use a really think piece of inlay.
I use a very aggressive 2 sided tape to hold the piece in place while I rout the inlay cavity.
The inlay material in finished thickness is most likely less than 1 mm
