It is currently Sun Jul 20, 2025 3:46 pm
 Post subject: Pickup wiring
PostPosted: Fri Jul 28, 2017 4:35 pm
First name: Gabe
Last Name: Spencer
City: Bellingham
State: Washington
Zip/Postal Code: 98225
Country: United states
Hello and thanks for having me! I'm a little ways into my first bass build and have some questions about the pickups. I bought some cheap amazon pickups and would like to wire four of them each to their own volume pot then straight to the input jack. Would anybody out there be willing to draw up a diagram for me?Image
 Post subject: Re: Pickup wiring
PostPosted: Sat Jul 29, 2017 5:34 pm
Where are the ground wires? Can't see them in the pics.
Sent from my SM-G920I using Tapatalk
PostPosted: Sun Jul 30, 2017 7:42 pm
First name: Gabe
Last Name: Spencer
City: Bellingham
State: Washington
It only has two wires Image
PostPosted: Sun Jul 30, 2017 9:05 pm
First name: Freeman
Last Name: Keller
Do you want switching or are you going to just turn the volume down/off? Any tone control?
If you PM me an e-mail address I can scan a simple wiring diagram from a Jazz Bass and send it to you
PostPosted: Mon Jul 31, 2017 2:15 pm
First name: Gabe
Last Name: Spencer
City: Bellingham
State: Washington
No tone control. Seems how it's gonna have four pickups I'm going to control the tone via pickup selection. No toggles just four volumes. Not to worried about spam here so my email is gabe61willys@gmail.com
PostPosted: Mon Jul 31, 2017 2:16 pm
First name: Gabe
Last Name: Spencer
City: Bellingham
State: Washington
I've seen jazz diagrams, can I just double that and omit the tone control?
PostPosted: Mon Jul 31, 2017 2:58 pm
First name: Freeman
Last Name: Keller
That is what I was going to suggest. The hot wire from each pickup goes to the center terminal of its pot (the sliding contact), one end of the pot is grounded and the other (top) end is in parallel with each of the other pots to the jack. If you take the pickup wire to the top end like many single pickup guitars you'll have a problem if you turn any pot to zero - it will kill all of them. Eliminate the tone circuit.
The J-bass diagrams that I have seen all use 250K pots - that is the normal value used with single coil pickup. Most humbuckers are happier with 500K (I assume thats true for basses too) and make sure you get "audio" or log taper instead of linear.
These users thanked the author Freeman for the post: Gabe61 (Mon Jul 31, 2017 3:03 pm)
