It is currently Thu Jul 17, 2025 6:37 am
PostPosted: Mon Jan 28, 2019 9:51 am
First name: Larry
Last Name: Hawes
Want to try a satin finish but really don't know where to start. I've been brushing a gloss water borne (EnduroVar) but have spray gear as needed. Looking for a thinner finish and trying to get off the high gloss train at the really nice satin finish station...
Thank You and Best To All
PostPosted: Mon Jan 28, 2019 10:41 am
If you're brushing you'll have to sand level and probably finish sand with a fine grit or non-woven abrasive.
I spray satin EV and am getting a thin coat (around 2.5/3 thou) with a reasonable finish off the gun
Take a bit of practice of course.
These users thanked the author Colin North for the post: Pmaj7 (Mon Jan 28, 2019 2:20 pm)
PostPosted: Mon Jan 28, 2019 10:53 am
I use Mohawk satin nitro straight from the gun for my satin finishes. I like it.
The only problem is that as you play it the neck gets glossy.....
PostPosted: Mon Jan 28, 2019 10:54 am
First name: Larry
Last Name: Hawes
Nice looking finish Colin. Are you pore filling?
PostPosted: Mon Jan 28, 2019 10:56 am
First name: Larry
Last Name: Hawes
Thanks Brad,
Been using True Oil for the neck with a 0000 steel wool rub and really like the finish...Also like not setting up a spray booth but may be a necessary evil...
PostPosted: Mon Jan 28, 2019 11:02 am
Zepoxy
PostPosted: Mon Jan 28, 2019 11:03 am
Here’s a picture of One of the guitars I used that lacquer on.
PostPosted: Mon Jan 28, 2019 11:16 am
First name: Larry
Last Name: Hawes
Nice Brad, is that a Cherry back?
PostPosted: Mon Jan 28, 2019 12:44 pm
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Colin what is EV?
PostPosted: Mon Jan 28, 2019 1:12 pm
First name: Larry
Last Name: Hawes
roby wrote:
Colin what is EV?
I'm guessing Enduro Var...
PostPosted: Mon Jan 28, 2019 2:23 pm
First name: Brad
Last Name: Combs
I was hoping Colin would chime in. :)
Larry, I think one of the keys for getting that nice off the gun finish will be a smaller tip (1mm) depending on your setup. I did a few test panels a while back following Colin's guidance and the 1mm tip made all the difference.
PostPosted: Mon Jan 28, 2019 2:58 pm
Last Name: Ensor
City: Springfield
State: Missouri
For satin finishes, I use a matte poly. It won't shine up with time and holds up nicely. I get a pretty good finish strait out of the gun, but I still rub it out a bit afterwards with super fine steel wool to get everything silky and even.
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: Pmaj7 (Mon Jan 28, 2019 6:51 pm)
PostPosted: Mon Jan 28, 2019 11:31 pm
Thanks.
It's flamed birch with a light amber stain.
PostPosted: Tue Jan 29, 2019 4:40 am
LarryH wrote:
roby wrote:
Colin what is EV?
Sorry for the shorthand, Enduro Var was mentioned in the OP (original post) oops_sign
Same for me, switching from the 1.3 original tip to the 1.0 seems to improve the atomisation, perhaps especially with the Fuji 3 stage turbine.
PostPosted: Tue Jan 29, 2019 8:22 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
A good quality satin finish will actually be a satin topcoat over a gloss base.... This is due to the fact that the refractory paste added to dull the finish also softens it. So a finish built out of entirely satin finish will wear away much quicker. This is why factory satin guitars often wear away to a gloss on the neck and under your arm.
The thing with a satin finish is it has to be an off the gun finish, you have no chance to level sand out nibs or surface texture. The typical process is exactly the same for gloss or satin until the last 2-3 coats (depending on type of materials used..) The keys to success here are the gloss coats must be completely dry so there will be no shrink back at all. This is then prep sanded one grit finer than typical for the finish and flow coats of satin finish applied.
Your spray environment and drying area must be almost surgically clean or dust nibs will ruin the finish. Your gun must atomize near perfect to keep orange peel down which will also ruin the look of the finish.
Brian
