It is currently Sun Jul 20, 2025 4:07 pm
PostPosted: Sat Feb 02, 2019 11:25 am
Last Name: Tracz
Hello all,
I’m planning the install for a mag mic in a guitar I’m building and wonder what everyone does with all the the extra wire. The cable going to the endpin jack is about twice the length isn’t needs to be. Do you just stuff it in there and hope it doesn’t rattle around? Or has anyone shortened it but cutting it off and solder the connections again?
I haven’t put the back on it yet and was thinking I would try and figure out wire routing while I have access.
I want to shorten it and make it as clean as possible on the inside. And I don’t want any wires hitting braces.
I’d love to know what you do. And let me m ow if I’m over thinking this.
Thank you in advance!!!
_Mike Tracz
MCT Guitars
https://www.instagram.com/mustcreatethings/
https://www.youtube.com/mustcreatethings
PostPosted: Sat Feb 02, 2019 11:30 am
I use wire clips from StewMac. Unless the wire length was really excessive I would likely not bother to cut it. I like to run the wires to the side near (but not on) the top so they can't be seen through the soundhole.
https://www.stewmac.com/Materials_and_Supplies/Glues_and_Adhesives/Tapes_and_Adhesives/Self-stick_Wiring_Clips_for_Acoustic_Pickups_6_Pack.html
I've found they stay on better if I use a small drop of medium CA on the self stick pad, something we used to do in manufacturing when putting selfstick pads on fiberglass.
PostPosted: Sat Feb 02, 2019 6:46 pm
Last Name: Tracz
Steve, thank you for the reply and link to the clips. Seems like the way to go. I have a little time before I have to pull the trigger on this and I’m going to have to resist clipping and splicing wires.
Here’s a photo of what I’m working with.
Thanks again for the reply and suggestion.
If anyone else has experience or a suggestion please toss it in the ring!
_Mike Tracz
MCT Guitars
PostPosted: Sat Feb 02, 2019 7:44 pm
Man that's a lot of wire. I definitely would not want it flopping around against the top. If you know exactly how you want to lay it out and can get into the jack I would consider making it shorter but would still route it around the side.
PostPosted: Sat Feb 02, 2019 8:26 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Haven't had to deal with this but as a sugestion you could fold the excess back and forth against the end jack and slip a piece of
heat shrink tubing over it to hold everything snugly to it... if you can snag a piece of heat shrink that is. Tape would do in a pinch
but the heat shrink would no doubt be a more professional choice.
PostPosted: Sat Feb 02, 2019 9:59 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We unsolder from the jack, trim to length, and resolder.
- Beth Brower
These users thanked the author Woodie G for the post: Mark L. (Wed Feb 13, 2019 2:32 pm)
PostPosted: Sun Feb 03, 2019 5:35 am
Last Name: Tracz
Awesome thanks guys! I think I’ll mark it for trimming but hold off and see if anyone else weighs in.
Much appreciated!!!
_Mike Tracz
MCT Guitars
PostPosted: Mon Feb 04, 2019 11:58 am
Trim it, for sure.
These users thanked the author Barry Daniels for the post: mtracz (Mon Feb 04, 2019 1:39 pm)
PostPosted: Sun Feb 10, 2019 8:59 am
Last Name: Tracz
Thank you Barry! That’s the plan now!!!
_Mike Tracz
MCT Guitars
PostPosted: Mon Feb 11, 2019 5:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Mini zip ties, stick on wire holders. I do that all the time on another pickup style
Users browsing this forum: Colin North, Kbore and 13 guests
