It is currently Sun Jul 20, 2025 6:29 pm
PostPosted: Wed Jul 03, 2019 2:23 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
For clearing small portions of the slot of CA, we use Mr. Breakstone's recommended StewMac hook tool and for wholesale slot clearing (where the luthier fretted with CA), a high wattage soldering iron with a 0.020" piece of scrap sawblade held in to a slot in the tip with a screw...good fume extraction is a must. A router speed controller does a good job of setting tip heat hot enough to melt the CA, but cool enough to avoid wood smoke.
Some fine points re: the hook tool:
- Resharpen the blade with a slip stone or fine half-round file...once dull, it takes a lot more force to cut the CA residue...proper function is a 'press-crunch'/repeat action. A fine Dremel sanding drum can be used as well, but use care to avoid heating the tip, as well as the direction of rotation due to safety concerns
- Do not use the binding as a fulcrum to lever out the last bit of CA...that will pop the binding loose with related finish damage (and turn air in shop blue )
- Take small bites, working from the center of the slot outward to the binding
- Beth Brower
These users thanked the author Woodie G for the post: Mike Baker (Wed Jul 03, 2019 2:57 pm)
PostPosted: Wed Jul 03, 2019 2:32 pm
meddlingfool wrote:
I wouldn't know, I'm non huffer:)
I was going to reply but I can't remember what I wanted to say....:)
PostPosted: Wed Jul 03, 2019 2:34 pm
Woodie G wrote:
For clearing small portions of the slot of CA, we use Mr. Breakstone's recommended StewMac hook tool and for wholesale slot clearing (where the luthier fretted with CA), a high wattage soldering iron with a 0.020" piece of scrap sawblade held in to a slot in the tip with a screw...good fume extraction is a must. A router peed controller does a good job of setting tip heat hot enough to melt the CA, but cool enough to avoid wood smoke.
- Do not use the binding as a fulcrum to level out the last bit of CA...that will pop the binding loose with related finish damage
Great stuff Woodie!
PostPosted: Thu Jul 04, 2019 5:14 pm
Success! I used an exacto knife I had, and followed all the cautions given here. Went smoothly.
My thanks to everyone. Much appreciated.
These users thanked the author Mike Baker for the post: Hesh (Thu Jul 04, 2019 5:29 pm)
PostPosted: Fri Jul 05, 2019 7:29 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Congrats! No doubt it took enough time that you’ve sworn never to get that much CA into a slot ever again. But you know what? It may happen anyway — I know I’ve been faced with slot cleanout after binding more than once, and the latest was just two weeks ago. Felt pretty stupid, but there ya go!
These users thanked the author Tim Mullin for the post: Mike Baker (Fri Jul 05, 2019 7:51 pm)
PostPosted: Fri Jul 05, 2019 7:53 pm
Yeah, wasn't a picnic for sure.
And yep, I shall endeavor not to do that again, lol.
But, I'm pretty sure it will happen again. At least I have the solution.
