It is currently Sun Jul 20, 2025 12:07 pm
PostPosted: Tue Oct 29, 2019 10:26 am
Quote:
….. spraying" also cools the air.....
Yes, the pressure drop results in a corresponding drop of about 30 degrees. If there is moisture in the air being sprayed, or if the humidity is high in the surrounding air - that temperature drop will cause the moisture to condense in the finish being applied.
That may be the case here, but the OP stated he is spraying a satin finish - meaning solids have been added. Therefore, I cannot state the exact problem or required fix for this guitar without eyeballing it in person.
These users thanked the author Chris Pile for the post: cablepuller1 (Tue Oct 29, 2019 3:17 pm)
PostPosted: Tue Oct 29, 2019 4:47 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Barry Daniels wrote:
This theory seems like a stretch. I have never seen this thinning issue from an RO sander and I use mine on guitars all the time.
Edit 1: The reflection of the braces is more likely due to the thermal mass of the bracing which slows down cooling and moisture condensation.
Edit 2: I added that last edit before I read Clay's post. You can see this thermal mass effect in windows and other areas where condensation occurs.
Do you realize the cause of most blush is at the aircap ? It occurs at high RH because water from the atmospheric air gets sheared into and picked up by the atomization. I have never witnessed a condition where a coating sprayed fine and blushed on the surface as it dries. The thermal condensation thing doesn't hold either..... never saw condensation form on a guitar in my shop or spray booth like a toilet tank or window pane as that is caused by big temperature differences on opposite sides of the surface. That doesn't happen here.
Edit 3: The overthinning of the top above braces can be minimized by using fresh sandpaper.
I have lost count of all the guitars I have finished built by all manner of folks over the past decade and I have seen it many times on work as it comes in. ALso, I change paper more often than most anyone I have met and can still see he condition appear in front of me if I use a RO so I sand by hand.
Do you realize the cause of most blush is at the aircap ? It occurs at high RH because water from the atmospheric air gets sheared into and picked up by the atomization. I have never witnessed a condition where a coating sprayed fine and blushed on the surface as it dries. he thermal condensation thing doesn't hold either..... never saw condensation form on a guitar in my shop or spray booth like a toilet tank or window pane as that is caused by big temperature differences on opposite sides of the surface. That doesn't happen here.
doncaparker wrote:
That's intriguing! Do you think the mechanism of injury is that the braced spots on the top provide more resistance to deflection, while the unbraced spots vibrate away from the sander? I am not disagreeing with you (I have no basis for disagreeing). I'm just trying to get a sense of how the problem happens.
Could be..... It's a vibration thing. Factories have less issue with this as most factory guitars are over braced. But a finer made instrument will vibrate freely and amplify those vibrations enough that RO sanding causes an issue. For example a RO running at 10,000 RPM will give an constant drive to the instrument of 160Hz, that's a constant E-3 note being played while you are sanding! Then there is the secondary frequency introduced by the random orbit which is slower producing a second, lessor constant input at somewhere around 30Hz or a B-0 note also constantly playing. So the top is vibrating, moving all the while you are trying to sand. Trying to work wood that is moving around never give optimum results.....
Brian
PostPosted: Tue Oct 29, 2019 6:48 pm
Brian Howard wrote:
"I have never witnessed a condition where a coating sprayed fine and blushed on the surface as it dries. The thermal condensation thing doesn't hold either..... never saw condensation form on a guitar in my shop or spray booth like a toilet tank or window pane as that is caused by big temperature differences on opposite sides of the surface. That doesn't happen here."
When the finish has blushed in that fashion (outlining the braces) with the instruments I was finishing, the initial coating looked fine, but began to blush soon after I finished applying it. It seemed to occur most often if I moved the guitar body from a warm room to a cold one to spray it, and if caught early enough the instrument could be moved back into a warm environment and the blushing would go away.
I think I also recently had to deal with the stearates coming out of the (satin) lacquer when spraying a 9 foot circular "arch" out of doors. The temperature and humidity were less than ideal and it was Watco brushing lacquer. At first I thought it might be severe blushing, but the white patches felt soapy and scraped off easily. Not a fun day of finishing.
PostPosted: Wed Oct 30, 2019 7:34 am
I could see that happening. I only started using an RO a couple years ago now and have not witnessed that problem but then I mostly French Polish too. But when using the RO on the top the guitar vibrates quite considerably for sure. In fact so much so that I was worried a bit about it. I figured who needs a Tonerite? Because using an RO will shake that thing in.
I guess the OP could solve this problem with one question, Did you use an RO on the top?
PostPosted: Wed Oct 30, 2019 10:11 am
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
I strikes me that the cause is much more simple. The top is more stiff where there's a brace so more wood is removed when you sand. Sanding by hand is less aggressive so the braces show less. I've observed this effect of braces showing on the top only when the top requires some aggressive sanding like removing an accidental scratch etc. Therefore I'm very conscientious about keeping the solera and top clean when gluing braces or attaching the top/back to avoid any excessive sanding since I've worked so hard to achieve the desired thickness (stiffness).
PostPosted: Wed Oct 30, 2019 3:13 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
This matches my experience I posted above. I was sanding by hand and was being too aggressive. I also assumed it was because of the added stiffness at the braces. The effect was diminished the further away from the X intersection and bridge plate I got. It served as a good lesson to be more mindful when I am sanding before finish. I always do it by hand so I was, perhaps, too complacent.
Bryan Bear PMoMC
