It is currently Wed Jul 30, 2025 3:37 am
 Post subject: Today's Find.
PostPosted: Sun Nov 17, 2019 4:59 pm
First name: Gregor
Last Name: Crothers
So, in a lot across from mine the developer decided to cut down this very large Willow tree.
It's likely that it is all going to just be burned, so i wrestled this round out of there today.
The main trunk is about 50% larger than this piece.
Are there any uses in guitar making?
I'm guessing maybe linings?
gregor
Wake up and smell the rosewood!
 Post subject: Re: Today's Find.
PostPosted: Sun Nov 17, 2019 5:06 pm
Nice score Gregor!
Blocks and linings, and maybe a couple of traditional Irish harp sound boxes if you were so inclined. They hollow out a baulk of willow to form the sides and sound board all in one piece.
PostPosted: Sun Nov 17, 2019 5:58 pm
Don't know if it's true or not, but I heard you could bend willow at .250 for one piece linings...
PostPosted: Sun Nov 17, 2019 6:10 pm
First name: Gregor
Last Name: Crothers
Thanks for the response Clay,
Neck and Tail blocks are possible as well? That's interesting.
I mean, I don't have really any experience with willow, but i do know that it is on the softer side.
.....which is probably why Ed has heard about bending at .250
I may get energetic and try get another piece out this week.
For now I rest..........feel like a wrestled a bear for an hour.
gregor
PostPosted: Sun Nov 17, 2019 8:20 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
I/ve used black willow and white willow which grows in MO . I like it for blocks and linings. It bends very well. Vlnmakers use it for blocks and lining.
PostPosted: Sun Nov 17, 2019 8:32 pm
It looks like wood, so I bet you could build a guitar from it ;)
PostPosted: Mon Nov 18, 2019 9:12 am
Willows usually grow in wet environments, when it is first cut much of the weight of this light weight wood is water:
https://sawmillcreek.org/showthread.php ... illow-Wood
PostPosted: Mon Nov 18, 2019 4:52 pm
First name: Gregor
Last Name: Crothers
Good to know Ernie.
Thanks for the link Clay.
PostPosted: Sun Dec 01, 2019 2:56 pm
First name: Gregor
Last Name: Crothers
Just a little update for those curious about this willow.
Considering using my axe instead of a plane after this. ; ) Can you say fibrous?
Stripping the bark off.
Leave it alone for awhile. Need to look for some old paint for the ends...likely frozen!
Im interested to see what it looks like after being sliced.
PostPosted: Mon Dec 02, 2019 4:48 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Willow is excellent for making cricket bats. But you probably already knew that.......
PostPosted: Mon Dec 02, 2019 10:09 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
I harvest local woods here in OK . For this willow . I wood debark it first . seal the ends with anchor seal . and then split it into 4 quarters to get the max quartersawn wood .Typically 1 in per yr so if your square is 5 by5 you could wait 5 yrs before resawing or make your own 1 in boards by resawing stacking and stickering them with 3/4in spacers.
PostPosted: Tue Dec 03, 2019 11:26 am
Last Name: Lee
Country: Wales U.K.
Why would a cricket want a bat? ;)
PostPosted: Tue Dec 03, 2019 12:48 pm
Maybe he already has a ball and glove.
