It is currently Thu Nov 28, 2024 1:32 pm
PostPosted: Wed Feb 12, 2020 7:37 pm
Last Name: Lloyd
After heavy use on the belt sander, especially with high resin woods, I'd use Easy-Off to soak the loose belt then rinse it in a bucket of warm water. It was always a messy job to do and clean-up.
So I decided to give it some thought for a better way and came up with this;
Using a piece of 4 1/2" PVC piping about 24" in length and 2 adjustable bands (a second modification). I now wrap the belts around the PVC pipe, spray with Easy-Off, let sit as directed then rinse with warm water and let dry.
No more messy cleaning and washing. :)
Michael Lloyd
These users thanked the author Michael Lloyd for the post: Pmaj7 (Wed Feb 12, 2020 9:54 pm)
PostPosted: Wed Feb 12, 2020 8:12 pm
Old tennis shoes work well, as well as natural rubber blocks available at suppliers.
PostPosted: Wed Feb 12, 2020 8:18 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Nice tip, Michael. I've been tossing my belts at that stage. Thanks to you I now know a way to salvage them, if I'm not to lazy.
PostPosted: Wed Feb 12, 2020 9:19 pm
City: Vancouver
Hmm....
PostPosted: Wed Feb 12, 2020 10:42 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
Though I generally avoid recommending Harbor Freight products, they sell a "Sanding Belt Cleaner" that's inexpensive ($8.50) and really works. It's a block of crepe rubber (1.5" x 1.5" x 8"). I rub it across my still running belt or drum sander after I'm finished sanding and the paper comes remarkably clean -- even with oily woods or glue residue.
These users thanked the author Hans Mattes for the post: Pmaj7 (Wed Feb 12, 2020 11:59 pm)
PostPosted: Thu Feb 13, 2020 11:13 am
Last Name: Lee
Country: Wales U.K.
You can also use old silicone sealant which has set inside the tube. Remove the tube first, of course.
These users thanked the author whiskywill for the post: Pmaj7 (Thu Feb 13, 2020 11:41 am)
PostPosted: Thu Feb 13, 2020 11:20 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I'd be concerned about silicone, even cured stuff, creating problems for finishing
on anything that gets sanded by said sanding belt.
Curious as to what everyone else thinks...
PostPosted: Thu Feb 13, 2020 6:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have never seen anything that will take African Blackwood or Cocobolo off of sand paper. Post videos of ur stuff doing it. I use easy off. When I need aggressive sanding on those woods, I use 36 grit. Never clogs. Trick is knowing when to stop and switch to 80 grit.
These users thanked the author Mike OMelia for the post: Michael Lloyd (Sat Feb 15, 2020 8:55 pm)
PostPosted: Fri Feb 14, 2020 6:39 pm
m
Remember Hush Puppies? They work too. They had crepe soles.
These users thanked the author Pat Foster for the post: Pmaj7 (Sat Feb 15, 2020 1:06 am)
Users browsing this forum: Bing [Bot], J De Rocher, Ken Nagy and 66 guests
