It is currently Sun Jul 20, 2025 1:42 pm
 Post subject: Bari scale length
PostPosted: Thu Feb 27, 2020 7:19 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
To keep the post simple, I play lap steel only, and want to make a baritone (electric/ acoustic later on)
that will work well with a C on the 6th string. That's a C below a standard E on the 6th string would usually be.
I've tried heavier gauge strings on a 25-1/2" scale length and unhappy with the sound.
So, any ideas what scale length to start at?
Thank you,
Alan
 Post subject: Re: Bari scale length
PostPosted: Thu Feb 27, 2020 7:27 pm
A 27 inch scale should work. C is only a whole step below dropped D which many people do on the low E string.
PostPosted: Thu Feb 27, 2020 8:07 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I made one with that exact tuning at around 27” scale length. It works well. I used a Fender bass fretting template from StewMac, but used one of the lower frets as the nut position. I can’t remember which fret on that template gives you a roughly 27” scale; I would have to check.
PostPosted: Thu Feb 27, 2020 9:40 pm
I have made an eight string acoustic baritone guitar with a 27 inch scale presently tuned in octave pairs CGDA and it works well. I know some lap steel players require tighter strings than what is desirable on a steel string guitar, but I think 27 inches will work O.K. as long as you aren't reaching for low B or A.
The baritone I built joins the neck at the 12th fret, so I can still use a standard case for it (probably not a consideration for a lap steel).
PostPosted: Thu Feb 27, 2020 10:19 pm
First name: alan
City: Santa Rosa
State: ca
Thank you all. Looks like 27" it be. Sounds right.
Good thing about a lap job is frets don't have to be that accurate, so I'll do it
the old fashioned way with a hundredth of an inch 24" ruler, and go blind.
Thanks again,
Alan
PostPosted: Fri Feb 28, 2020 6:30 am
I used a bass guitar fretboard and cut off a couple of frets at the nut end (I bought 50 "rejects" off eBay for $1 apiece some years back)
