It is currently Fri Nov 29, 2024 10:43 am
 Post subject: Pore filling with epoxy
PostPosted: Wed Jun 17, 2020 8:14 am
First name: Roy
Last Name: Ott
City: Vancouver
State: Washington
When pore filling with epoxy (or any other pore fill for that matter) do you sand all the way back to the wood leaving just the pores filled or do you level the epoxy so there is an even coat of it on the wood prior to spraying the finish?
Thanks!
Roy
PostPosted: Wed Jun 17, 2020 9:40 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Yes! Truly at times I do one or the other. With deeper pore wood I leave a thin level film for two reasons: If I can sand to a thin film I know I am truly level before spraying and I will avoid sand-throughs while leveling the top finish. While sanding back to wood new pores are opened, as the pores are at a random depth there will be some with just a hint of wood bridging them.
PostPosted: Wed Jun 17, 2020 9:43 am
Personally I don't stress about it. I try to level the epoxy so there is a fairly even coat and then I do wash coats all over to cover where the wood has been exposed with 1:8/10 epoxy/IPA to eliminate "blotching", let dry and scuff before spraying.
PostPosted: Wed Jun 17, 2020 9:47 am
With any pore filler I always sand back to wood. Some will leave a very thin layer of finshing epoxy on but not your standard hardware stuff. I like to go back to wood leaving only the pores filled seems like that is the way pore filling was designed to do.
PostPosted: Wed Jun 17, 2020 10:18 am
First name: Freeman
Last Name: Keller
I sand the first two applications of finishing resin back to the wood, then apply one more coat highly diluted with DNA. That soaks into the wood like straight DNA does and really enhances the wood. It only needs very light scuffing before the sealer goes on.
PostPosted: Wed Jun 17, 2020 11:54 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I leave a thin film of epoxy over the whole surface because sanding back to wood can open up new pores and I like how it enhances the appearance of the grain. With Z-poxy, I've used the same approach as Colin. I recently used SilverTip epoxy for the first time and as it happened I was able to level sand it without going through anywhere so it didn't need a wash coat. So I haven't tried the wash coat step with SilverTip yet, but I expect it would work.
PostPosted: Wed Jun 17, 2020 1:02 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
With my limited experience, I sand back to wood and finish off with a wash coat. I chose to do this so as to be sure of limiting thickness buildup. For me, if I didn't do that I would have no idea of the thickness of what I left on. So far, pleased with the results.
Peter Havriluk
PostPosted: Wed Jun 17, 2020 1:28 pm
City: Vancouver
I leave a thin film. I use a single edge razor with rounded corners to scrape, rather than sand. Once level, I scuff with scothbrite...
PostPosted: Wed Jun 17, 2020 8:34 pm
When I epoxy pore fill, I don't pore fill the soundboard - it is not needed and that is where a thin film of finish is most critical.
PostPosted: Wed Jun 17, 2020 9:34 pm
City: Vancouver
Agreed and likewise...
PostPosted: Thu Jun 18, 2020 7:31 am
First name: Roy
Last Name: Ott
City: Vancouver
State: Washington
What is IPA?
PostPosted: Thu Jun 18, 2020 7:57 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Either hoppy beer, or 99% Isopropyl Alcohol....
These users thanked the author Robbie_McD for the post: Durero (Thu Jun 18, 2020 2:22 pm)
PostPosted: Thu Jun 18, 2020 2:06 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
It does work. I use EverClear to thin it, FWIW.
These users thanked the author saltytri for the post: J De Rocher (Thu Jun 18, 2020 4:45 pm)
PostPosted: Thu Jun 18, 2020 10:34 pm
First name: Roy
Last Name: Ott
City: Vancouver
State: Washington
Thank you everyone for all the quick responses. It's always appreciated. I only wish I would have known earlier to not pore fill the sound hole. I think that might be why I don't have good sustain. :=)
PostPosted: Fri Jun 19, 2020 7:19 am
It takes an awful lot of epoxy to pore fill a soundhole! laughing6-hehe
Users browsing this forum: Alan Carruth and 81 guests
