It is currently Sun Jul 20, 2025 1:29 am
PostPosted: Wed Aug 19, 2020 1:48 pm
Hi
Please attach pictures of your rosette sound hole edging
I'm in desperate need of inspiration, particularly dark woods surrounding the sound hole, im really stuck for what to do with mine, have some bogoak I can use, abalone,rosewood and some other bits
Tia
Sent from my SM-A715F using Tapatalk
PostPosted: Wed Aug 19, 2020 2:40 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
I've always been a fan of Michihiro Matsuda. He is always thinking "out of the box" and has some very clean, contemporary designs. You might find a bit of inspiration here that isn't quite along the "traditional" vein. YMMV
https://www.flickr.com/photos/matsudagu ... 947267253/
Peter
These users thanked the author Peter J for the post: cablepuller1 (Wed Aug 19, 2020 2:47 pm)
PostPosted: Wed Aug 19, 2020 3:12 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
The rosette is only for decoration -- so, IMHO, it should harmonize with your headplate, your binding and purfling, your fretboard and bridge, and your tail decor (wedge or ?). And they should all harmonize with each other -- and with the wood species used for the top and for the sides and back. When you're finished the guitar will look more "put together" if they all do. If possible, all these elements should be chosen early in the build process. Matsuda does a wonderful job at that.
I've seen some truly beautiful rosettes that actually detracted from the guitar (again, IMHO) because they had no relevance to anything else in the build.
These users thanked the author Hans Mattes for the post (total 2): Pmaj7 (Fri Aug 21, 2020 12:00 pm) • cablepuller1 (Wed Aug 19, 2020 3:37 pm)
PostPosted: Wed Aug 19, 2020 3:42 pm
Thanks, this was what I'm thinking, I have some spare bogoak that matches the back/sides and headplate
But might be a bit too much dark wood ?
PostPosted: Wed Aug 19, 2020 3:57 pm
I learned that the rosette was not solely for decoration but to strengthen around the opening of the sound hole. I do believe there is some truth to this but perhaps not.
PostPosted: Wed Aug 19, 2020 4:09 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
This is my last one - all Alaskan Yellow Cedar including the neck. The binding and the soundhole binding is black plastic, but any dark wood would look nice there
Ed
These users thanked the author Ruby50 for the post (total 2): bftobin (Sun Aug 30, 2020 4:26 pm) • cablepuller1 (Thu Aug 20, 2020 12:41 am)
PostPosted: Wed Aug 19, 2020 6:55 pm
Last Name: Kincheloe
Here's my very first one. I need to do another this style sometime, with imagery over a solid ring background framed by purfling rings.
All the ones I've done since have been open designs, with imagery inlaid straight into the softwood. I often put something at the top left corner, oriented so it doesn't look upside down in either hanging on the wall or playing position. And usually a painting inside the soundhole, which may or may not combine with the rosette.
The harp guitar is probably my favorite. Quite a challenge coming up with how to do those thorns, and the proper sequence to get the vines intertwined without any gaps, and getting the whole thing shellacked without the rosewood tree branch from bleeding everywhere. And the pumpkin's face is actually cut through to the inside of the soundbox :) I had originally planned to glue gold MOP to the back side of it so the face would be recessed and look like it's glowing from inside. But I like this even better.
These users thanked the author DennisK for the post (total 2): Skarsaune (Thu Aug 20, 2020 11:05 am) • cablepuller1 (Thu Aug 20, 2020 12:41 am)
PostPosted: Wed Aug 19, 2020 6:59 pm
If you did a typical veneer type rosette in bog oak with a thin line of paua within it, and then use it for position markers and possibly an peghead inlay it might be fairly easy to do and look nice .
A shell design inlaid into the bog oak similar to japanese lacquerware might look nice but be a little more work.
https://www.rubylux.com/item/1429688-AS ... quer-Box78
http://www.creative-museum.com/en/conte ... -hairpin-3
These users thanked the author Clay S. for the post: cablepuller1 (Thu Aug 20, 2020 12:42 am)
PostPosted: Thu Aug 20, 2020 10:26 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Wow wow wow! Now I have to learn to do that!
Hutch
PostPosted: Thu Aug 20, 2020 10:45 am
Last Name: Orr
This is my last one, 84 hand cut pieces of maple veneer set in a bog oak dust/epoxy mix with bwb purfling on either side.
These users thanked the author Bob Orr for the post (total 3): cablepuller1 (Thu Aug 20, 2020 3:32 pm) • Colin North (Thu Aug 20, 2020 3:15 pm) • bcombs510 (Thu Aug 20, 2020 10:59 am)
PostPosted: Thu Aug 20, 2020 11:05 am
First name: Richard
City: Warwick
State: RI
Dang, add another year on to my build process.
Hutch
These users thanked the author banjopicks for the post: cablepuller1 (Thu Aug 20, 2020 3:32 pm)
PostPosted: Thu Aug 20, 2020 11:06 am
First name: Chuck
Last Name: Skarsaune
City: Butler
Nice work Dennis K, way to get out of the box.
PostPosted: Thu Aug 20, 2020 11:24 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I have been using spalted maple ala Greenfield andDannyV. Partly because I have a pile of spalted cut-offs, but mostly because I think it looks great.
These users thanked the author Bri for the post: cablepuller1 (Thu Aug 20, 2020 3:32 pm)
PostPosted: Thu Aug 20, 2020 1:48 pm
First name: Aaron
I used to do simple shell inlay, and now do my true "radial rosette", unless its a custom request.
Anybody see joints? There are none (there’s a spalt gap that I left in).
Most of my binding is koa, so it disappears in the context of the whole build, intentionally.
These users thanked the author Aaron O for the post: cablepuller1 (Thu Aug 20, 2020 3:32 pm)
PostPosted: Thu Aug 20, 2020 3:57 pm
First name: Richard
City: Warwick
State: RI
You guys are all thinking outside the box. I have to build another guitar just to try some of these ideas out.
Hutch
These users thanked the author banjopicks for the post: cablepuller1 (Fri Aug 21, 2020 1:25 am)
PostPosted: Thu Aug 20, 2020 4:23 pm
Here's one from a few years back. The dark wood is ziricote, as are the B&S and headplate.
These users thanked the author Pat Foster for the post: cablepuller1 (Fri Aug 21, 2020 1:26 am)
PostPosted: Fri Aug 21, 2020 7:38 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
A few years ago Robbie O’Brien compiled a collection of rosette designs contributed by members of OLF and other forums. You can see it in this video (the gallery of rosettes starts at about 7:30).
https://m.youtube.com/watch?v=PFxfdpbfw_U
These users thanked the author Mark Mc for the post: cablepuller1 (Fri Aug 21, 2020 9:43 am)
PostPosted: Fri Aug 21, 2020 9:37 am
Redwood Burl outlined with plain old BWB
These users thanked the author Colin North for the post: cablepuller1 (Fri Aug 21, 2020 9:43 am)
PostPosted: Fri Aug 21, 2020 10:04 am
Little fancier, on a hybrid classical. Spalted beech/thin herringbone, with 1mm BWB inside, 1.3mm BWB outside the bones.
These users thanked the author Colin North for the post: cablepuller1 (Sat Aug 22, 2020 2:26 am)
PostPosted: Fri Aug 21, 2020 10:30 am
Last Name: Colbert
City: Anacortes
Here are a couple,
These users thanked the author Michaeldc for the post (total 2): cablepuller1 (Sat Aug 22, 2020 2:27 am) • Colin North (Fri Aug 21, 2020 10:40 am)
PostPosted: Fri Aug 21, 2020 10:40 am
Mr Colbert, that is really crisp clean work.
These users thanked the author Colin North for the post: Michaeldc (Fri Aug 21, 2020 10:56 am)
PostPosted: Fri Aug 21, 2020 10:59 am
Last Name: Colbert
City: Anacortes
To be honest and up front, the channels are cut cnc. All of the purflings are cut, mitered and installed by hand.
M
These users thanked the author Michaeldc for the post (total 2): cablepuller1 (Sat Aug 22, 2020 2:27 am) • Colin North (Fri Aug 21, 2020 2:31 pm)
PostPosted: Fri Aug 21, 2020 12:33 pm
Curly maple on spruce & abalone on redwood.ImageImage
These users thanked the author Pmaj7 for the post: cablepuller1 (Sat Aug 22, 2020 2:27 am)
PostPosted: Fri Aug 21, 2020 1:40 pm
Here's one from a classical guitar I'm working on. The woods are all natural colors. I make the parts using hand plane jigs, and build up the rosette in place.
Here's how I use this on steel strings.
These users thanked the author Alan Carruth for the post (total 4): cablepuller1 (Sat Aug 22, 2020 2:27 am) • Pmaj7 (Fri Aug 21, 2020 3:06 pm) • jshelton (Fri Aug 21, 2020 2:45 pm) • Michaeldc (Fri Aug 21, 2020 1:49 pm)
PostPosted: Fri Aug 21, 2020 3:06 pm
Alan, what is the shiny material in the first one?
