It is currently Thu Sep 18, 2025 11:51 am
 Post subject: Common Compound Radii
PostPosted: Mon Nov 02, 2020 9:59 am
Last Name: Ensor
City: Springfield
State: Missouri
What are the most common/your favorite compound radii for fretboards? E.G.- 16" to 20"
Thanks.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Mon Nov 02, 2020 10:50 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Chris Ensor wrote:
What are the most common/your favorite compound radii for fretboards?.
On my steel-string guitars: 12 to 14 with 16” saddle, and 14 to 16 with 18” saddle.
On my classicals 16 to 20”
PostPosted: Mon Nov 02, 2020 11:17 am
steel strings 16-20
PostPosted: Mon Nov 02, 2020 1:12 pm
PostPosted: Mon Nov 02, 2020 1:56 pm
I like 12" - 16" at 12th, 20" of course at saddle. Steel string.
PostPosted: Mon Nov 02, 2020 1:58 pm
Tim Mullin wrote:
On my steel-string guitars: 12 to 14 with 16” saddle, and 14 to 16 with 20” saddle.
Think that's a typo - 12 to 16 with 20” saddle? or 14 to 16 with 18" saddle?
PostPosted: Mon Nov 02, 2020 3:51 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Colin North wrote:
Tim Mullin wrote:
On my steel-string guitars: ..., and 14 to 16 with 20” saddle.
Think that's a typo - 14 to 16 with 18" saddle?
Yes, now corrected in post.
PostPosted: Mon Nov 02, 2020 4:08 pm
Last Name: Ball
I radius my fingerboards on a CNC router. I tend to like 12" radius boards, so I start with that at the nut. Then in my CAD model of the fingerboard tapered to final width, I draw a straight line down the side of the fingerboard, parallel to the bottom of the board and at the height that the 12" radius at the nut dictates. This will keep the side height of the fingerboard uniform over the length of the board. Finally, I draw whatever radius it takes at the end of the board to hit the edge where I want it and the centerline of the top of the board. I've never bothered to actually measure what the radius is there--probably pretty close to the 16 inches others are using. It's easy enough to extend the model all the way to the saddle to find the matching radius there too.
I probably didn't describe this process very well, but it's quick and easy to do and makes a nice looking and playing compound radius.
PostPosted: Mon Nov 02, 2020 4:48 pm
I start out with the 16 at the nut and 20 at the end but then I level the string paths before I fret the board so not sure where the saddle end of the board actually ends up.
PostPosted: Mon Nov 02, 2020 4:59 pm
Last Name: Ball
I actually hadn't thought about it before, but I think that my CAD based compound radius method probably goes back to what I learned from Charles Fox at Earthworks back in the 70's. There, we radiused our fingerboards with a hand plane, keeping a constant edge thickness and sort of blending it towards the centerline of the fingerboard. Sometime I'll have to measure the radii of the guitar I built up there. I can pretty much guarantee it isn't a consistent radius over the length of the board.
A lot of what I learned up in Vermont seems to have sunk into my subconsciousness, reappearing frequently through the years, but not necessarily recognized as such. I think that's a sign of a very effective teacher.
PostPosted: Mon Nov 02, 2020 6:45 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I do something very close to this. I first plane/sand a constant 16" radius into the board, which is already tapered in width before I start the radiusing. Then I use a narrow straight-edged sanding beam to sand each string path flat along its length, blending a bit across the board to make sure there are no noticeable facets. This yields a conical board that is roughly 16" radius at the nut and roughly 20"-ish radius at the end of the board.
I maintain that, as long as the board has some sort of radius that is comfortable to the fretting hand, and each string path is flat along the run of each string, that is all the "compound radiusing" the player needs. It winds up being a de facto compound radiused board, without worrying too much about the specific radii.
These users thanked the author doncaparker for the post: SteveSmith (Mon Nov 02, 2020 6:55 pm)
PostPosted: Mon Nov 02, 2020 8:34 pm
Last Name: Kincheloe
That's what I do as well, but now that I think about it I'm not sure it actually produces a conical board since I focus the beam sanding toward the middle of the board to remove the apparent hump in the paths of the outer strings. The nut and end should both still have 16" radius.
I tried modelling it in Blender, and the radius varies in a strange pattern. It starts out at 16" at the nut, then becomes smaller, reaching a minimum around the 4th-5th fret, then gradually increases, hitting 16" again at the board end, and larger as you head toward the bridge and beyond. The string paths are straight while following the board taper, but the shape is not conical. I'm not 100% sure, but I think it's actually superior for string bending. On a cone, pulling a string to the side causes an apparent hump to appear in the path again, but because this one has a sort of concavity to it, you can pull farther before anything bad happens.
