It is currently Sat Jul 19, 2025 2:08 pm
PostPosted: Sat Mar 13, 2021 1:29 pm
First name: Brad
Last Name: Combs
Hello,
A couple weeks back I accidentally knocked over a sheet of plywood in the shop. The plywood knocked this plate off the bench and, ala Rube Goldberg, a large bottle of titebond rolled off the bench onto it, snapping it in half.
It closes up nicely but I’m not sure how to clamp it. Maybe just the tape method? Any other suggestions? I tried to fit it into an LMI plate joining jig but it doesn’t line up well because it’s already trimmed to 00 shape.
Brad
PostPosted: Sat Mar 13, 2021 1:48 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Tape it. If I need extra clamping pressure, I use long strips of tape, stretching it over the edges.
Sent from my SM-G950U1 using Tapatalk
These users thanked the author John Arnold for the post: bcombs510 (Sat Mar 13, 2021 2:14 pm)
PostPosted: Sat Mar 13, 2021 2:11 pm
My two cents. If you decide to wrap extra tape, rope, clamp, etc. then support the pieces with some cross boards so they do not buckle. You might also want to consider interior reinforcement across the repair, though if the glue joint is perfect, that might be superfluous. I am not sure if even the tape is useful, because with the kind of joining where you need each little irregularity to fit, the tape might interfere. Maybe just glue and leave it on the table. When I do that, I cover the exposed side of the joint with wax paper, so there is no differential drying to buckle the wood.
I do not know if your wood would stain from CA. I have glued BRW top and back by laying them on the table on wax paper, fitting the pieces tightly, then flooding repeatedly with thin CA several hours apart. From tests, I found that a single flooding was all soaked up and did not glue the joint.
These users thanked the author wbergman for the post: bcombs510 (Sat Mar 13, 2021 2:14 pm)
PostPosted: Sat Mar 13, 2021 2:30 pm
First name: Brad
Last Name: Combs
Thanks both!
Tape seemed to work well, I got squeeze out all along the joint. I clamped it up between two pieces of plywood. I even got to use my Jesus take the wheel clamps. I haven’t used those in a while. :D
These users thanked the author bcombs510 for the post: Pmaj7 (Sat Mar 13, 2021 3:27 pm)
PostPosted: Sat Mar 13, 2021 3:57 pm
That's a bad omen when glue breaks it!
I'd throw that glue away.
Glad you got it fixed.
These users thanked the author Jim Watts for the post: bcombs510 (Sat Mar 13, 2021 4:38 pm)
PostPosted: Sat Mar 13, 2021 3:58 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I’d like to see what a Jesus take the wheel clamp looks like.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: bcombs510 (Sat Mar 13, 2021 4:38 pm)
PostPosted: Sat Mar 13, 2021 4:40 pm
First name: Brad
Last Name: Combs
Haha, its really any clamp you can use one handed, but I was referring to these:
Brad
These users thanked the author bcombs510 for the post: Bryan Bear (Sat Mar 13, 2021 9:53 pm)
PostPosted: Sat Mar 13, 2021 6:46 pm
Ha! Love it.
PostPosted: Sat Mar 13, 2021 6:54 pm
By the way, what species of wood?
These users thanked the author wbergman for the post: bcombs510 (Sat Mar 13, 2021 7:41 pm)
PostPosted: Sat Mar 13, 2021 7:44 pm
First name: Brad
Last Name: Combs
Black walnut from Ohio. I got two sets of it from American Tonewood. The sets were so thick I had half a mind to resaw the two into four. :D
PostPosted: Sun Mar 14, 2021 8:39 am
First name: Brad
Last Name: Combs
Appreciate the help. It’s nearly invisible with the exception of a small area where a splinter was lost. I tried to find it when it happened, but no dice. :)
Brad
PostPosted: Sun Mar 14, 2021 8:53 am
Make a splinter from scrap. Doesn't matter if it is high--that can be leveled easily.
These users thanked the author wbergman for the post: bcombs510 (Sun Mar 14, 2021 9:01 am)
PostPosted: Sun Mar 14, 2021 10:23 am
Great fix! I just saw the thread, but I was thinking tape, too. I’m glad it did the trick!
These users thanked the author James Orr for the post: bcombs510 (Sun Mar 14, 2021 11:02 am)
cron
