It is currently Sun Jul 20, 2025 6:34 pm
 Post subject: Buffing with ROS
PostPosted: Sat Mar 20, 2021 5:47 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
That didn't work I hoped. I can get a good shine but its leaving scratches behind, I sure miss my SM buffer. I think it's too slow. Next up in my effort to avoid a giant buffer and save some pennies, the drill press. I just ordered some 3" foam pads for it.
Hutch
 Post subject: Re: Buffing with ROS
PostPosted: Sat Mar 20, 2021 6:40 am
First name: Richard
City: Warwick
State: RI
I just came up with the perfect buffer. My lathe. I can't believe how well it worked. I was concerned with having enough room but it turned out be a non issue, at least with the electric guitar I'm buffing. I may try some 12" wheels when I finish my acoustic.
Hutch
PostPosted: Sun Mar 21, 2021 9:30 am
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I saw one of Beau Hannam's videos where he used the Makita variable speed ROS. I tried one but I hated the grip and it was noisy and vibrated a lot so I returned it. I bought the Bosch variable speed ROS and love it. I final sanded a guitar with 1000 grit, then I used the Micro-Mesh series with 2400 up to 12,000 grit and the guitar looks great. I had to do the waist area by hand but use Micro-Mesh there also. It didn't take very long to do it.
Kent
PostPosted: Mon Mar 22, 2021 8:32 am
First name: Richard
City: Warwick
State: RI
Trust me, the lathe and small buffer is a real time saver and I don't like extended sanding sessions. I'm pretty sure I can go from 800 grit to this buffer. When I had the SM buffer I would go straight from 400 grit and let the buffer do the work.
Hutch
PostPosted: Mon Mar 22, 2021 9:33 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I like the lathe idea. Did you use standard cotton buffing wheels like StewMac sells? And, how fast did you run the lathe?
PostPosted: Tue Mar 23, 2021 2:39 pm
First name: Richard
City: Warwick
State: RI
The buffing wheel has been in my tool box for too many years to know where it came from. Definitely not SM just a standard big box thing. I don't know how fast but it was a lot faster than my ROS. Probably 1200 rpms.
Hutch
PostPosted: Wed Mar 24, 2021 11:28 am
Do you have a picture of your lathe buffing setup? Did you mount it to the outboard side of the lathe?
PostPosted: Wed Mar 24, 2021 12:32 pm
Last Name: Ball
Beall Tools has made a lathe buffing system for years--not really well suited to something as big as a guitar, but a similar device could be made. Their system consists of a mandrel that has a MT2 on the headstock end, and the other end is held in a live center on the tailstock. The buffer works over the bed of the lathe.
PostPosted: Wed Mar 24, 2021 12:42 pm
First name: Richard
City: Warwick
State: RI
The buffer in the chuck was for inside the horns and the one in the bed is the one I used to buff the electric guitar. It worked great but I'll need to figure a way to attach an outboard wheel. I think I can come up with something.
Hutch
PostPosted: Wed Mar 24, 2021 2:34 pm
As Dave mentioned:
https://www.woodcraft.com/products/beal ... uff-system
Users browsing this forum: doncaparker and 16 guests
