It is currently Sat Jul 19, 2025 4:40 pm
 Post subject: Unslotted Bridge Pins
PostPosted: Sun Apr 24, 2022 11:26 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Where are folks getting their unslotted bone bridge pins? Paying for Waverly pins seems insane when you can get good slotted pins at half the price. Looking for 3 degree taper.
Thanks!
Tony Thatcher
Bozeman, Montana
PostPosted: Sun Apr 24, 2022 11:46 am
My stock came from LMI - https://www.lmii.com/search?controller=search&s=bridge+pins+3+degree+unslotted
Search results not specifically unslotted, but they are in there.
Got some from bone ones china via ebay too.
Used to be a supplier in the States or Canada selling 3 degree unslotted wooden pins on ebay.com in bulk, but can't find him at the moment
PostPosted: Sun Apr 24, 2022 12:21 pm
I had an OLFer make mine and he did outstanding work. I'm trying to remember his name and it's escaping me but if you search on bridge pins and me as the author we may find it. Mine were unslotted, 3 degree and I would send him BRW and cocobolo to make mine and one time some African Blackwood.
All my guitars were 3 degree unslotted and every one of them the bridge plates look like new still.
Each one was individually made on his lathe and I don't think he was CNC either. Old school baby! :)
These users thanked the author Hesh for the post: Pmaj7 (Sun Apr 24, 2022 2:49 pm)
PostPosted: Sun Apr 24, 2022 12:35 pm
I just fill the slots with little slips of Corian. Small slips of hardwood might work as well and give a "designer" element to the pin.
These users thanked the author Clay S. for the post: Pmaj7 (Sun Apr 24, 2022 2:49 pm)
PostPosted: Sun Apr 24, 2022 1:54 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Bob Colosi of www.guitarsaddles.com
These users thanked the author Toonces for the post: Pmaj7 (Sun Apr 24, 2022 3:09 pm)
PostPosted: Sun Apr 24, 2022 4:59 pm
First name: Tom
Last Name: Rein
City: Saline
David Warther
Stay with the happy people.
--Reynolds Large
PostPosted: Sun Apr 24, 2022 6:47 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I bought a couple of gross from Michael Gurian (gurianinstruments.com). I sent him a block of Persimmon and he turned them into pins. He said he had a machine that popped out one every 7 seconds. The cost was quite affordable. You have to contact them and work out your specifics.
Before that, I turned some myself. You know how to make a set of matching pins? You make a whole bunch and then sort them into sets where 6 sort of match. I still turn my own end pins and the larger bridge pins for acoustic basses.
These users thanked the author bobgramann for the post: CraigG (Sun Apr 24, 2022 8:13 pm)
PostPosted: Sun Apr 24, 2022 8:57 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
You can just turn the slot towards the back and the unslotted side towards the saddle.
PostPosted: Mon Apr 25, 2022 4:28 am
Mark no offense intended but I would advise against this.
Presumably someone asking for 3 degree, unslotted pins is going to do what you have to do when you use unslotted pins and that is slot the bridge plate, top and bridge. If you prepare the guitar, convert it or build it for unslotted pins and slotted pins are used and the slot is forward the string and string ball will damage the bridge plate very, very quickly. It's effectively doubling the clearance for the wrapped and ball end of the string and that permits the string ball to be pulled up the pin hole and lodge wherever it chews it's way to.
We've seen this before and the damage is so extensive to the bridge plate that capping was not appropriate and the plate had to be replaced or should have been replaced so that's what we did.
So sure you can turn the slots around but if you ever forget or someone else services the guitar or even restrings it and is not knowledgable about slotless conversions substantial and expensive damage to the guitar can result.
Just better to use unslotted pins and keep it simple.
PostPosted: Mon Apr 25, 2022 6:30 am
I hear that Hesh, but I have noticed I can remove my unslotted bridge pins and still have the strings under tension.
These users thanked the author Colin North for the post: Hesh (Tue Apr 26, 2022 3:17 am)
PostPosted: Mon Apr 25, 2022 11:12 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Thanks for the ideas, all. I sure can't find any bone unslotted pins on LMII. They are my usual go to for pins, but since finally getting on the slotted bridge bandwagon, I can't find any for a reasonable price from the standard sources. Seems that unslotted should be cheaper than the slotted! I sent LMI a message to see if they are hidden somewhere. And it seems their out of stock for a lot of Bone pins. Perhaps I'll try some wood ones.
For now I'll turn my pins backwards until I can track down some unslotted pins.
Tony Thatcher
Bozeman, Montana
PostPosted: Mon Apr 25, 2022 1:39 pm
Last Name: Dzatko
Japarts in Vancouver Canada has them.
japarts.ca
PostPosted: Mon Apr 25, 2022 3:07 pm
Might have been Burton LeGeyt.
These users thanked the author Pat Foster for the post: Hesh (Tue Apr 26, 2022 3:15 am)
PostPosted: Mon Apr 25, 2022 5:29 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
If you turn them 1/4 turn instead of halfway the tip doesn't collapse as easily.
Hey! Just searched for "unslotted" pins at LMII and they listed Ebony and Rosewood 3 degree pins. bliss
PostPosted: Tue Apr 26, 2022 1:29 am
CarlD wrote:
......................... Hey! Just searched for "unslotted" pins at LMII and they listed Ebony and Rosewood 3 degree pins. bliss
Wish I'd said that laughing6-hehe
PostPosted: Tue Apr 26, 2022 3:16 am
Nope not Burton and I'm still trying to remember who it was they did great work.
PostPosted: Tue Apr 26, 2022 3:23 am
Sure that's because the string balls are over the slots and not between the pin and the slot from an unslotted pin. It's very possible for an slotted pin slot forward to not push the string ball back into the slot in the plate, top and bridge and when that happens if you pull that pin the string comes up too. This is when the string ball does the most damage to the bridge plate when it's slotted for unslotted pins and slotted pins are used.
Dave Collins did a presentation on this at the Northwood Seminar using examples of bridge plates going back to 1870. It's an interesting subject how with the advent of cheap, molded bridge pins this part of guitar construction changed.
If I remember I'll take some pics of his presentation that is on our wall and post it.
PostPosted: Tue Apr 26, 2022 6:34 pm
I would offer that Hesh may be thinking of Custom Inlay for bridge pins
https://custominlay.com/shop/ols/produc ... dot-inlays
These users thanked the author Mike Franks for the post: Hesh (Wed Apr 27, 2022 4:04 am)
PostPosted: Wed Apr 27, 2022 4:03 am
Hey Mike, hope you are doing great.
No not them who made mine was just a member here and he did not have a company of sorts or was affiliated with one. A man with a lathe so-to-speak :)
PostPosted: Wed Apr 27, 2022 4:07 am
Found it, it was Louis!!! Louis sorry for my bad memory I'm like WIllie Nelson and a life long pot smoker. :)
http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=14415&hilit=+BRW+bridge+pins+
So no clue what-ups up with Louis these days it's been a long time since we were in touch.
PostPosted: Wed Apr 27, 2022 4:09 am
These users thanked the author Hesh for the post: Burton LeGeyt (Wed Apr 27, 2022 1:03 pm)
PostPosted: Wed Apr 27, 2022 5:57 am
Last Name: Kincheloe
Hey Chris Ensor, after reading that thread Hesh linked, I think we have a new Elevate tool for you to make :) One-pass bridge pin head cutter for lathe. I know I'd like to have one.
My favorite material for bridge pins is sycamore sticks from the back yard. They have a nice radial pattern, and similar color to the boxwood pins LMI sells. Fairly soft, but with a slotted bridge the strings aren't bearing on the pins when under tension.
PostPosted: Wed Apr 27, 2022 6:57 am
First name: Josh
Hesh wrote:
They look real nice, Hesh. The unslotted pins I use (Gurian) aren’t as nicely finished as those.
These users thanked the author joshnothing for the post: Hesh (Wed Apr 27, 2022 1:18 pm)
PostPosted: Thu Apr 28, 2022 9:44 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
Hesh wrote:
I had an OLFer make mine and he did outstanding work. I'm trying to remember his name and it's escaping me :)
There was an OLF gathering 8 or 10 years ago that was hosted in someone's buisness in Lake Zurich, Illinois. I don't recall his name but he was making bridge pins.
Kent
These users thanked the author kfish for the post: Hesh (Sun May 01, 2022 11:09 am)
Users browsing this forum: Bing [Bot] and 12 guests
