It is currently Sat Jul 19, 2025 9:45 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 14, 2023 4:11 pm
City: Escondido
Zip/Postal Code: 92029
You can mount the electronics using thumbwheels in the sound hole. It’s what I do. I wouldn’t add a finger rest just to have a place for a knob. That seems like the tail wagging the dog.
PostPosted: Wed May 17, 2023 9:58 am
Thank you. In this case the floating pickup must be screwed to the fingerboard and the wire is visible.
PostPosted: Wed May 17, 2023 12:06 pm
City: Escondido
If you want a finger rest, use one. But please believe me that you don’t need one just for a pickup. It’s not theoretical knowledge. I made several this way before I stopped building.
PostPosted: Wed May 17, 2023 1:26 pm
Congratulations for the beautiful guitar. I’ve seen your work before, nice design. I assume that a hole is drilled in any plcenfor rhe cables.
Please, can I ask you about this pickup?
PostPosted: Wed May 17, 2023 2:10 pm
City: Escondido
Yes, a small hole let’s the wires pass through. If you look closely you can see the thunbwheels in the sound hole.
The pickup is a Pete Biltoff made pickup. It is absolutely my favorite for this application. It is deep and rich but still has some sparkle of a CC style pickup. The Kent Armstrong and Bartolini sound a bit muddy to my ears. He even sends you both Anilco II and Anilco V magnets so you can see which one you prefer.
https://vintagevibeguitars.com/windows/sc_ccwin.html
PostPosted: Wed May 17, 2023 2:13 pm
City: Escondido
I should add that Pete is great to work with. He picks up the phone and answers emails. Tell him what you are looking for and he will steer you in the right direction.
PostPosted: Wed May 17, 2023 4:39 pm
This is a very valuble information for me. Thank you very much for your time and the detailed description. Kind regards.
PostPosted: Thu Aug 31, 2023 7:33 am
Hello,
I’m in the moment of fret leveling, but I have a inconvenience: the firgerboard is a bit convex (1/64 aprox) so I can have a flat fingerboard for start the leveling.
The trussrod is a single direction one, hence I can’t adjust it in order to obtain a flat fingerboard.
Once the strings are mounted I will no longer have this problem because the trussrod will perform its function.
Any tip for keep the fingerboard flat during the leveling work?
PostPosted: Thu Aug 31, 2023 7:35 am
“I can’t have a flat fingerboard”
PostPosted: Thu Aug 31, 2023 8:00 am
Sounds like you did something wrong during construction...
PostPosted: Thu Aug 31, 2023 8:10 am
First name: Josh
String it up and see if there’s enough string tension to pull the neck straight or into relief, then adjust rod and level with understring beams. If you cannot get it to a point where you can level it and relax the rod for a hair of relief afterwards you may need to mill your desired relief into the frets.
For future builds consider using a double-action rod as insurance against this issue.
These users thanked the author joshnothing for the post: Chris Pile (Thu Aug 31, 2023 10:03 am)
PostPosted: Thu Aug 31, 2023 10:26 am
Thank you. I think the fret channels are a bit narrow hence this minor curve
PostPosted: Thu Aug 31, 2023 10:57 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Maybe a PLEK job (if available) would be in order here?
https://plek.com/plek-for-guitarists/plek-repairshops/
Measure Twice,
Karl Borum
PostPosted: Thu Aug 31, 2023 12:01 pm
Thank you, The problem is just fret leveling, when the guitar it’s strung the problem will be solved.
PostPosted: Thu Aug 31, 2023 5:24 pm
We don't need no PLEK round here. ;-)
These users thanked the author Barry Daniels for the post: Juan CAR (Fri Sep 01, 2023 9:55 am)
Users browsing this forum: Peter J and 10 guests
