It is currently Fri Nov 22, 2024 8:10 pm
 Post subject: Delta planer question…
PostPosted: Wed Dec 06, 2023 11:48 pm
City: Vancouver
I recently acquired a Delta 12.5” planer. I don’t know how I’ve worked so long without one, total game changer for dressing billets. I was just marveling at how much faster the work went rather than with a drum sander when it started making a vibrating noise and then poof, a puff of smoke and it stopped working.
I took it apart and found that the bolt holding the pulley on the blade assembly had loosened and allowed the pulley to damage itself on the drive shaft and the belt had come off. I think I can get away with a bit more work with the existing pulley while trying to find a new one, but the belt…
Do belts shrink? The belt is so short there’s absolutely no way of getting it back on the pulleys, it doesn’t even come close.
So I guess the main question is, can drive belts shrink?
PostPosted: Wed Dec 06, 2023 11:51 pm
City: Vancouver
PostPosted: Thu Dec 07, 2023 8:46 am
I've had the same planer for probably 15-20 years now and have not touched it ever except to change blades of course. Hmmmm, maybe I should have a look at it :D
My guess is there is some sort of belt adjustment? Sort of like the alternator on your car maybe? I would not think belts like that would shrink. If anything I could see them expanding.
PostPosted: Thu Dec 07, 2023 9:32 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Perhaps, the wrong belt for this machine....since the bolt backed off and you recently acquired it.:)
PostPosted: Thu Dec 07, 2023 10:15 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
That belt looks toasted anyway. When you order a replacement, maybe it will be the right size?
PostPosted: Thu Dec 07, 2023 10:28 am
Online
First name: Brad
Last Name: Combs
Making an assumption this is a 22-560. FWIW, at 2:56 you can see the part number - https://youtu.be/sYkctrRAV9M?t=176
Looks like maybe this one? https://www.amazon.com/Planer-Replaceme ... B07Q3LM6HN
PostPosted: Thu Dec 07, 2023 10:44 am
City: U.P.
I was curious to see how the planer worked mechanically and came across a pretty good video. Brad beat me to the submit button, same video.
edit (Link removed)
I think the guy should have replaced the pulley too and the wobble was most likely do to the inside bore of the pulley being worn when it was loose.
From the comments it looks like the pulley nut gets loose with some regularity.
A drop of removable lock-tite might be worthwhile on the nut threads.
Looks like the belt stretches a fair amount in assembly.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: bcombs510 (Thu Dec 07, 2023 10:52 am)
PostPosted: Thu Dec 07, 2023 12:59 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I had a look at that video linked above. https://www.youtube.com/watch?v=sYkctrRAV9M
Looks to me like your belt is shorter than that one in vid. At 19 min. shows putting belt back on.
If that doesn't work for you look up the proper belt size for your model... at least you'll know if you have the right one.
+1 on the lock tite.
PostPosted: Thu Dec 07, 2023 1:14 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Oh and to answer your main question:), nope, I've never seen a belt shrink...stretch, yes.
One other thing, if you have the correct belt, you could put it in boiling hot water for a few minutes
before attempting to put it on.
These users thanked the author Ken Lewis for the post: bcombs510 (Thu Dec 07, 2023 2:30 pm)
PostPosted: Thu Dec 07, 2023 2:31 pm
Online
First name: Brad
Last Name: Combs
That’s a great tip!
PostPosted: Thu Dec 07, 2023 3:44 pm
City: Vancouver
Thanks for the vid! Unfortunately, the pulley is cracked, and new pulleys are no longer available. However when reassembled, with the nut tightened, the assembly feels solid.
The belt is the one that came of the machine. So I guess it must be able to go back on somehow. I’ll get a new one and have a go…
PostPosted: Thu Dec 07, 2023 5:11 pm
Grainger has micro-ribbed v-belts. Might find something there.
PostPosted: Thu Dec 07, 2023 5:24 pm
City: Vancouver
lol, just got back from there, no luck in Canada. I’ll have to order a new one online…
PostPosted: Thu Dec 07, 2023 5:41 pm
City: U.P.
Is this the pulley?
[url]delta planer chtterhead pulley 1342156[/url]
https://www.renovoparts.com/1342156-cutterhead-pulley/
N8ZED
PostPosted: Thu Dec 07, 2023 6:51 pm
City: Vancouver
Wow! This place is the best! Part ordered, thank you…:)
Though I just can’t comprehend how the old belt won’t go back on…it’s simply too small…
These users thanked the author meddlingfool for the post: Kbore (Fri Dec 08, 2023 11:53 am)
PostPosted: Fri Dec 08, 2023 7:14 am
This doesn’t make sense … smh
PostPosted: Fri Dec 08, 2023 8:28 am
Is that some sort of belt tensioner behind the lower pulley?
PostPosted: Fri Dec 08, 2023 8:38 am
Reading the reviews might answer some of your questions, especially about "shrinkage" (Caused by being too hot rather than too cold. Ha!):
https://www.amazon.com/DELTA-22-560-2-I ... B00005S7TK
These users thanked the author Clay S. for the post: Kbore (Fri Dec 08, 2023 1:00 pm)
PostPosted: Fri Dec 08, 2023 9:28 am
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
If it is a DW733 then the belt number is 285968-00.
Seems Amazon.ca has some replacement
https://www.amazon.ca/Planer-Replacement-285968-00-Craftsman-351217130-2/dp/B07TPHKY5L
The pulley is 285066-00
https://www.amazon.ca/DEWALT-28596600-Pulley/dp/B00XNN0IFS/ref=sr_1_9?crid=2VD5UJVLFXEZZ&keywords=dw733+pulley&qid=1702045719&s=hi&sprefix=dw733+pulley%2Ctools%2C69&sr=1-9
PostPosted: Fri Dec 08, 2023 12:12 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
THe drive belt marking were clear @ 3:08.
I did an A.I. search from that video.
Here are the AI results:
Here is what each of the markings mean:
140J: This refers to the belt’s section type and size. The “J” section is a metric standard for ribbed belts, and the “140” indicates the belt’s length in millimeters.
P24: This marking indicates the belt’s pitch length, which is the distance between the centers of two adjacent teeth. In this case, the pitch length is 24 millimeters.
925: This marking indicates the belt’s width in millimeters. In this case, the belt is 925 millimeters wide.
Maybe this adds some food for thought.....
Measure Twice,
Karl Borum
PostPosted: Fri Dec 08, 2023 12:20 pm
City: Vancouver
Well…dang. That’s what you get for free I guess.
These users thanked the author meddlingfool for the post: Kbore (Fri Dec 08, 2023 12:59 pm)
Users browsing this forum: bftobin, Bing [Bot], zmp2 and 43 guests
cron
