It is currently Sat Jul 19, 2025 11:13 pm
 Post subject: Cam clamps wood choice
PostPosted: Fri Jan 26, 2024 7:09 pm
I'm going to build some cam clamps and thought oak would make a good choice but the last few times I've worked with oak, I've gotten skin and eye reactions. What's a good alternate to oak? Ash?
Thanks in advance,
PostPosted: Fri Jan 26, 2024 7:25 pm
I think I would go for beech.
These users thanked the author Colin North for the post: Kbore (Sun Jan 28, 2024 12:34 pm)
PostPosted: Fri Jan 26, 2024 7:46 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Mine are made out of maple.
These users thanked the author doncaparker for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Fri Jan 26, 2024 7:57 pm
The ones I made I used maple too.
These users thanked the author SteveSmith for the post: Kbore (Sun Jan 28, 2024 12:34 pm)
PostPosted: Fri Jan 26, 2024 8:11 pm
First name: Trevor
Last Name: Gore
City: Sydney
The traditional timber to use is Hornbeam. Mine are made from Aus. blackwood (higher density stuff) and work fine with aluminium shanks. I didn't use pins on the sliding part and they still work perfectly some 15 years on.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Kbore (Sun Jan 28, 2024 12:32 pm)
PostPosted: Fri Jan 26, 2024 8:13 pm
City: U.P.
Just a vote for hickory. Made some I like, strength to weight is good.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Fri Jan 26, 2024 9:51 pm
I've made quite a few and mostly from maple. I have few long reach ones from my early archtop, parallel brace days that have a 9" reach and are, without running down to measure, 1 1/2" by 1 1/2" wooden bars with 1 1/4" x 1/8" steel flatbar that can put some serious clamping pressure down compared to the average cam clamp.
These users thanked the author Darrel Friesen for the post: Kbore (Sun Jan 28, 2024 12:33 pm)
PostPosted: Tue Jan 30, 2024 12:27 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I used oak (leftover flooring I glued up). Price was right - - - zero. Waste not, want not. And I figured the time spent was worth it, I didn't grudge the time.
Peter Havriluk
PostPosted: Sat Feb 03, 2024 1:42 pm
I've used several woods over the years. I'm not a fan of Ash. The best wood for me has been Birch and Hard Maple. In fact, I have some that I used Hard Maple for the bar instead of metal.
Brent
PostPosted: Sat Feb 03, 2024 1:57 pm
I made mine out of maple, they work great.
PostPosted: Sun Feb 04, 2024 9:00 am
I recently made about 50 clamps to go completely around a guitar body when gluing on the back or top. I went a different direction and made the clamps from 3 layers of 1/4" Baltic birch plywood so I didn’t have to cut mortises. They’re not super strong but are up to job they are intended for.
PostPosted: Sun Feb 04, 2024 10:15 am
Do you prefer cam clamps to a go bar deck Barry?
PostPosted: Mon Feb 05, 2024 9:19 am
Yes I do, for this specific operation. Go bars work great for bracing but did not work that great for me when clamping tops or backs to the rim. I built a body for an old Martin 00-17 that has no body binding and I discovered that I was not getting a completely closed joint line due to the go bars not applying pressure in exactly the right spot along the outside of the joint. Cam clamps do a better job of closing the joint especially if you position them so that the flexible clamp pad can shift and follow the slightly tilted edge of the arched rims.
