It is currently Sat Jul 19, 2025 12:58 pm
PostPosted: Fri Mar 29, 2024 12:24 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
What is your approach in flat sanding lacquer considering CAMI and FEPA grits during the process?
I have been starting with P1200 which is equivalent to 3M's 600 CAMI grit.
I have amassed a great selection of both grades (Kovax, Mirka, 3M ect), but using both in the same sanding schedule (converting/ equivalence/ best practice) is starting to concern me in respect to the "quality" and thickness of the final finish, in regard to the sandpaper I used (US or P graded). P1200 is equivalent to US 600 grit, and I am questioning what to even start with now.
Many of these grading systems charts are available, are they all correct?
https://abrasives-south.com/wp-content/ ... 8x1324.jpg
https://www.abrasiveresource.com/v/vspf ... arison.pdf
Measure Twice,
Karl Borum
PostPosted: Fri Mar 29, 2024 1:31 pm
Micron size.
You should be able to find a chart listing micron size for the various systems.
I have one I printed out many years ago. I can intermingle systems that way.
I find it helpful.
These users thanked the author Jim Watts for the post: Kbore (Fri Mar 29, 2024 3:48 pm)
PostPosted: Fri Mar 29, 2024 3:11 pm
Just within the last month I finally got all of my sandpaper changed out so I'm only using P grade. I got tired of using the chart to see what was what. All told it probably cost me about $200 since I only use the good stuff. I think it was worth it.
These users thanked the author SteveSmith for the post (total 3): Robbie_McD (Thu Apr 11, 2024 8:43 am) • Pmaj7 (Thu Apr 04, 2024 10:06 pm) • Kbore (Fri Mar 29, 2024 3:48 pm)
PostPosted: Fri Mar 29, 2024 5:12 pm
I'm with you Steve. I stay with P grade for finishing and Cami/micron for sharpening on my 1" x 42" belt sander and Veritas powered sharpener. Less confusion for me for sure.
These users thanked the author Darrel Friesen for the post (total 2): Kbore (Fri Mar 29, 2024 11:50 pm) • SteveSmith (Fri Mar 29, 2024 7:47 pm)
PostPosted: Fri Mar 29, 2024 11:19 pm
For sanding finish materials I like to use micron discs. The "grit" is on a Mylar backing and is of a uniform size so the sanding scratches are more uniformly sized. You can wash and dry the discs so they last longer than regular sandpaper. For finer sanding the Trizact discs work well, also on Mylar and fairly long lasting.
For sanding wood I still use Cami and P grade papers.
These users thanked the author Clay S. for the post: Kbore (Fri Mar 29, 2024 11:51 pm)
PostPosted: Sat Mar 30, 2024 2:03 pm
when you get info finishing this is a whole new ball game. Look up asilex paper you won't turn back this stuff is amazing
These users thanked the author bluescreek for the post (total 3): Robbie_McD (Thu Apr 11, 2024 8:44 am) • Pmaj7 (Fri Apr 05, 2024 5:51 pm) • Kbore (Sat Mar 30, 2024 8:48 pm)
PostPosted: Sat Mar 30, 2024 8:50 pm
First name: Karl
Last Name: Borum
What is a good schedule for lacquer using the micron scale ?
Measure Twice,
Karl Borum
PostPosted: Sat Mar 30, 2024 10:13 pm
I like to go 60 micron (remove orange peel),30 micron (flatten), 15 micron , green trizact, blue trizact, (remove scratches) then buffing compounds (polish).
Micron chart:
https://support.wickededgeusa.com/porta ... sion-chart
Being uniformly sized particles, when the micron scratches start disappearing the rest quickly follow, and then it's time to move to the next size down.
These users thanked the author Clay S. for the post (total 2): Robbie_McD (Thu Apr 11, 2024 8:44 am) • Kbore (Sat Mar 30, 2024 10:42 pm)
PostPosted: Mon Apr 01, 2024 9:32 am
First name: Karl
Last Name: Borum
Micron chart:
Are these micro grades always used dry?
Measure Twice,
Karl Borum
PostPosted: Tue Apr 02, 2024 10:10 am
Kbore wrote:
Micron chart:
I like to use them wet with an orbital sander set at a slower speed for the flat surfaces, and by hand (or with a hand held block) for the last centimeter near the edges. Trying to sand up to the edge with a powered sander usually leads to burn throughs for me. A small amount of detergent in the water seems to help. The discs are on Mylar film and hold together even when wet and can be washed and dried for reuse several times.
Trizact is used wet also and behaves similarly.
These users thanked the author Clay S. for the post (total 2): Pmaj7 (Fri Apr 05, 2024 5:53 pm) • Kbore (Tue Apr 02, 2024 3:24 pm)
PostPosted: Tue Apr 02, 2024 3:30 pm
First name: Karl
Last Name: Borum
Thanks for replies, its new territory for me. I have multiple different books, LMI's verbose Lacquering instruction and JJ's finishing class on-line, and they all use traditional wet sanding paper and schedules. Bet this is going to cost me $$$ :shock:
Measure Twice,
Karl Borum
PostPosted: Wed Apr 03, 2024 10:33 pm
If you go to an auto parts store that sells auto paint you may find 5" micron and trizact discs you can buy by the piece. You probably only need one each to finish a guitar (possibly a couple of guitars).
These users thanked the author Clay S. for the post (total 2): Pmaj7 (Fri Apr 05, 2024 5:54 pm) • Kbore (Thu Apr 04, 2024 5:34 pm)
PostPosted: Thu Apr 04, 2024 9:11 pm
First name: Karl
Last Name: Borum
I'll give the auto paint and supply store a whirl. I used to go there to buy Wet or Dry by the sheet.....almost forgot!
Measure Twice,
Karl Borum
PostPosted: Wed Apr 10, 2024 1:38 pm
First name: Karl
Last Name: Borum
Would the 3m Brand of micro graded paperbe appropriate (lacquer flattening/ finishing)?
Assilex/ Tolex are confusing to me.
Excerpt:
The superior flexibility of the non-woven, tear-resistant synthetic backing on this Polishing Paper allows for fast and easy finishing and polishing of numerous materials, even on highly contoured surfaces. They are excellent for finishing jewelry and precious metals. They will remove scratches and restores transparency to acrylic and polycarbonate windows on buses, aircraft and trains. They are ideal for plastic, polyurethanes, fiberglass, solid surface composites and wood. Their precision micron grading provides a uniform, consistent finish which shortens hand-sanding and buffing time, reduces finishing steps and saves time. They can be easily cut into strips. They can be used wet or dry. These sheets will not load or clog easily, and can be washed with soap and water. Polishing paper available with micron graded silicon carbide or aluminum oxide minerals. Sheets are color-coded for easy identification.
Set includes the following grades:
30 micron (600 grit) Silicon Carbide, Army Green
15 micron (1200 grit) Silicon Carbide, Grey
9 micron (1800 grit) Aluminum Oxide, Sky Blue
3 micron (8000 grit) Aluminum Oxide, Pink
2 micron (10,000 grit) Aluminum Oxide, Aqua Blue
1 micron (14,000 grit) Aluminum Oxide, Ivory.
All sheets are Non PSA (Pressure Sensitive Adhesive). All sheets are 8-1/2" x 11".
Measure Twice,
Karl Borum
PostPosted: Wed Apr 10, 2024 3:06 pm
Excerpt:
The 3M brand materials I have worked with have always been first rate, if a little bit more expensive than some other brands. With the small quantities most of us would use over the course of a year it probably doesn't matter. I haven't used the finest grades mentioned (usually go to polishing compounds) but I would be interested in how they might work out.
These users thanked the author Clay S. for the post: Kbore (Wed Apr 10, 2024 7:08 pm)
Users browsing this forum: Ken Lewis, Michaeldc and 25 guests
