It is currently Sat Jul 19, 2025 6:26 pm
 Post subject: Guitars #2, 3, & 4
PostPosted: Wed Apr 10, 2024 9:51 pm
First name: Thomas
Last Name: T
Since I spend so much time, figuring out how to do my next step, I decided to do three guitars at once, so I could just repeat the step for all three guitars. I’m building one for myself, one for my daughter, and one for my son.
 Post subject: Re: Guitars #2, 3, & 4
PostPosted: Wed Apr 10, 2024 10:06 pm
First name: Thomas
Last Name: T
Some more pics
PostPosted: Wed Apr 10, 2024 10:14 pm
First name: Thomas
Last Name: T
Here’s my powered radius dish sander. Worked like a dream. Lot of dust, but very easy. Just need a dust mask and hold the rims there.
With doubled up sides and solid kerfing, this really would have been a lot of sanding.
PostPosted: Wed Apr 10, 2024 10:16 pm
Very nice work Thomas and it looks like you have a very cool shop too.
PostPosted: Wed Apr 10, 2024 10:27 pm
First name: Thomas
Last Name: T
Thanks, I converted part of my shop into a woodshop
These users thanked the author guitarmaker78 for the post: Hesh (Sat Apr 20, 2024 6:49 am)
PostPosted: Thu Apr 11, 2024 5:41 am
Nice work, I like the inlays on the top.
PostPosted: Thu Apr 11, 2024 6:40 am
First name: Ken
Last Name: Nagy
City: Goodrich
Is that curly Mahogany for the fronts of 2 of them. It is stunning. All of the wood choices are good.
It seems that you have it figured out. The blue rings around the sound holes tie them together. Modern building always looks neater. I guess my building just needs to not bypass the fixing up ALL THE WAY part.
Is the inlay flooded black epoxy?
Why be normal?
PostPosted: Thu Apr 11, 2024 6:52 pm
Looks great Thomas. Do you add side reinforcements/bracing at all? I've just always done it with spruce braces as Benedetto's book has influenced a lot of my building techniques.
PostPosted: Thu Apr 11, 2024 9:29 pm
First name: Thomas
Last Name: T
Two are all Mahogany and the third is Brazilian Rosewood with a Spruce top.
The inlay is Ebony. I glued two head plates together and cut the rosette inlay first, then from the center cutout that was left over, I cut the crosses inlay. I also used some of the excess to cut the inlay for the neck block on the Brazilian Rosewood guitar.
PostPosted: Thu Apr 11, 2024 9:48 pm
First name: Thomas
Last Name: T
I added side reinforcements to the second guitar, which is the one with marbled Koa. On the Koa guitar with the Crosses and the Brazilian guitar, I laminated the sides so I didn't add any side braces. The sides are very strong and a crack would be stopped by the inner layer. The Brazilian is .087 thick with a .093 East Indian Rosewood inner layer. The inlayed Koa guitar sides are .100 thick with a Mahogany inner layer that is .080.
I made a mold to hold the sides and glued them together using epoxy. I bought large vacuum storage bags on amazon and put my vacuum pump on it instead of the included hand pump.
My "kerfing" is Spanish Cedar.
PostPosted: Sat Apr 20, 2024 3:29 am
First name: Thomas
Last Name: T
It took me a minute to figure out how to bend the purfling around the side of the guitar. I put it in the sink for a few minutes, then taped it to the side form I made.
