It is currently Thu May 01, 2025 10:01 am
PostPosted: Thu Jun 08, 2006 5:59 am
Okay, glued a bridge on, using a damp paper towel to clean away the squeeze out...thought I had it all, but now I notice a thin film of glue along the back side of the bridge...not a glue line, but a "smear" running along the back edge of the bridge exactly, or almost exactly, the width of my index finger...how to go without removing my finish?
PostPosted: Thu Jun 08, 2006 7:28 am
Larry
If it's Titebond I agree with Hesh it should come off as it Shouldn't adhere to the finish very well.
PostPosted: Thu Jun 08, 2006 8:11 am
Sweet! Now, I should start another thread on this, but since I have you here...the file ordeal has left me with a slightly loose bridge pin that wants to pop up when the string's at pitch...I've always had pins fit too tight if anything...what's the normal fix here?
PostPosted: Thu Jun 08, 2006 8:15 am
[QUOTE=L. Presnall] Sweet! Now, I should start another thread on this, but since I have you here...the file ordeal has left me with a slightly loose bridge pin that wants to pop up when the string's at pitch...I've always had pins fit too tight if anything...what's the normal fix here?[/QUOTE]
Put the file back in - that should keep the string in nice and snug
PostPosted: Thu Jun 08, 2006 11:07 am
Man Dave, that file's never going near a guitar again!
PostPosted: Thu Jun 08, 2006 11:37 am
Larry- You can get oversize bridge pins from Stew-Mac
DaveAndy38876.8612962963
PostPosted: Thu Jun 08, 2006 11:45 am
Larry,
Frank Ford has a procedure on his web site about fitting an end pin that's too tight. It should work on bridge pins also.
PostPosted: Thu Jun 08, 2006 1:15 pm
WHOA! Just wick a little superglue into it (if you're careful, you can use a Q-tip)
Put rag inside guitar
BEOFRE applying superglue to Q-tip, rotate Q-tip between fingers to pack the fibers in. (Loose fibers cause the superglue to flash dry too quickly)
Charge with superglue and wick it in.
Woolson & I have had this work well for us.
PostPosted: Thu Jun 08, 2006 2:03 pm
Dip the peg in superglue and let it dry. Add as many coats as needed. (never tried this but it sounds good to me)
PostPosted: Thu Jun 08, 2006 2:29 pm
Thanx guys! You guys always come thru!!
