It is currently Wed Aug 20, 2025 4:11 pm
 Post subject: oh no, Neck problem
PostPosted: Sun Jan 23, 2011 2:55 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Well I was carving a neck today and got a little too into it. In the first position I shaved it down to 1/2 an inch (not including the fretboard). I have a really large 2 way trussrod in it, but I'm not sure if this neck is trash or still good. The neck is a 1 piece spanish cedar neck BTW. Thanks, Brian
 Post subject: Re: oh no, Neck problem
PostPosted: Sun Jan 23, 2011 2:58 pm
THat wouldn't be bad for me. I use an allied rod so not bad. I don't know what rod you are useing though.
PostPosted: Sun Jan 23, 2011 3:45 pm
That would depend on the trussrod size, which is ???
Would help to know how much wood is left under the rod!
e.g. 10 mm rod would leave only 2,7 mm wood - I've been told 3mm is about a minimum.
PostPosted: Sun Jan 23, 2011 4:13 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Another option would be to add two carbon fibre rods on either side of
the truss rod. You'd have to slot all the way into the headstock to get
the strength back, so you'd have to redo any peghead cover layer- don't
know if you've got one on it or not. If not, it'd be easy to add one after
bonding in the fiber rods. LMI has 3/16"x1/4" rods, or 1/4"x3/8" that
would work, Not cheap though. Depends on how attached to this neck
you are...
Gene
PostPosted: Sun Jan 23, 2011 6:11 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
it's a martin 2 way. I got it from the martin GMC over the summer. It's blue if that helps.
PostPosted: Sun Jan 23, 2011 11:02 pm
What's the depth needed for that rod? You should have .13" left to be safe. Clinton
