It is currently Sun Jul 20, 2025 3:52 am
PostPosted: Fri Apr 18, 2008 1:35 pm
I am using the vintage Schaller tuners and am preparing to drill the holes. I have read every scrap of info in the archives and it looks like 10mm or 25/64" is the best bet for drilling the holes. My question though (and I'm having trouble interpreting in the archives) is can you use this bit all the way through? Or do you absolutely need to drill 1/4" first and then ream for the bushing. I am hoping to hear I can use the one-size bit straight through. This would leave the hole from the back side bigger than necessary - but with the tension on the bushing it seems like it wouldn't really matter. Correct me if I am wrong - my wife always does. duh
Christian
PostPosted: Fri Apr 18, 2008 2:34 pm
Christian, I haven't used the vintage Schallers yet (I'd like to though) but I did find this review on the 13th fret about them.
Sounds like you drill the hole clear through (I use 25/64" drill for my Schaller tuners).
PostPosted: Fri Apr 18, 2008 3:21 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
10mm all the way through !
Protect the wood the bit will come through with a wood caul clamped tight to it!
So you do not tearout that wood.
Al will be fine!
I've done hundreds of these! [:Y:]
After finishing the hole will have to be cleaned of finish -the hole will be smaller because of the finish build-up!
Mike Collins
PostPosted: Fri Apr 18, 2008 5:41 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
To clean the hole out of finish, just put the 10 mm bit in your drill chuck, and turn the chuck by hand.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sat Apr 19, 2008 2:27 am
Thanks for the info - I used the drill press and the correct bit and it worked out just fine! Awesome.
Christian
