It is currently Fri Aug 22, 2025 10:34 am
PostPosted: Tue May 31, 2011 9:01 am
I had a few guys coming over to check out some of my guitars, knowing they were strummers, not fingerstlye, so I installed removable pick guards to protect the finish. Afterwards, I left one on for several months and when I removed it, well, not a warm feeling. [headinwall] Ruined the finish underneath. I thought I would share my experience in the hopes that it saves someone else this warm feeling. Clinton
PostPosted: Tue May 31, 2011 10:36 am
Last Name: Conery
I had a bad finish problem with a French polished top last year when I left a Kling On on it for several weeks - against the manufacturer's instructions. gaah
The problem area recovered somewhat over the next several months, but eventually needed to be refinished.
http://coneryguitars.com
Kill your television!
PostPosted: Tue May 31, 2011 10:49 am
Well, it seems you are damned if you do, and damned if you don't.
I had a guy come by with a repair, and to test a new guitar, and I had been thinking I would put a clear pickgard on it, but didn't.
Sure enough, he scraped up the finish, and I had to re-polish the area.
I was so mad, I added $100 extra to his repair quote. After doing the repair, there was more to do than I estimated, and the money came out about right.
What to learn? Get mad at everyone bringing in a repair job!
That doesn't help you with YOUR problem, I don't know what the cling-on is made of that would react so strongly with shellac and varnish.
It must be vinyl.
PostPosted: Tue May 31, 2011 4:50 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
It's vinyl. I've used them on oil varnish finished guitars, but only after it's cured for at least a month, and I always remove it after playing.
Added/Edit, I would suspect results could vary depending on the finish manufacturer too.
