It is currently Tue May 27, 2025 10:03 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 31, 2007 3:37 am
Country: Romania
well the saddle fit is pretty much there, but not the way I would like- will deal with this asap.
I usually hate medium tension strings. They do produce a warmer sound and its easier to nuance, but I can't control them too well. My fingering is sloppy...
If the combo is too stiff, then it needs a lot of tension I guess.  Think at a steel string, or a 10 string classical. Those have a massive bridge but more tension.
Anyway, In the mean while, I think it has opened up a little. And also sounds a bit more mellow.
Build log
PostPosted: Fri Aug 31, 2007 4:08 am
Country: Romania
here are a few measures from Lauro's Cancion.
Build log
PostPosted: Fri Aug 31, 2007 6:51 am
I believe you are right.  I would like to hear the trebles sing a little more (personal taste).  How does it sound on the upper frets.  Does it maintain it's evenness?
PostPosted: Fri Aug 31, 2007 6:57 am
Country: Romania
no upper frets yet :D
Build log
PostPosted: Fri Aug 31, 2007 7:05 am
Ahh!  That splains it!
PostPosted: Fri Aug 31, 2007 9:47 am
First name: Josh
Last Name: French
City: Houston
Alex, where did your bridge weight end up?
I just cut a blank to size because I'm about to make a bridge for the latest guitar. Out of curiosity I decided to weigh it before doing anything to it (ie. carving it) and it weighs only 37 grams.
Instagram: @jfrenchluthier
PostPosted: Fri Aug 31, 2007 9:51 am
Country: Romania
I'm certain has not gone under 30.
regarding blanks, mine are 205x55x12mm and weight 130 grams.
Build log
PostPosted: Fri Aug 31, 2007 10:29 am
First name: Josh
Last Name: French
City: Houston
I'm getting about 90 at close to those dimensions for BRW.
PostPosted: Sat Sep 01, 2007 7:08 am
First name: Josh
Last Name: French
City: Houston
Just an update Alex - my bridge came to 18g.
Brazilian Rosewood: 185mm x 28mm x 8mm, bridge wings at 4mm.
Also 18 holes but I expect that accounts for about a third of a gram.
Its going on one of my smaller guitars, so I intended to keep it light. But its no different then my other bridges really.
