It is currently Sun Jul 20, 2025 6:08 pm
PostPosted: Mon May 21, 2007 4:23 am
HELLO FRIENDS!!
Does anyone have a used Martin 6 string neck?
I desperately need a neck in good condition.
I prefer a 1 3/4" width at the nut, but will take a 1 11/16". The Martin Logo is not needed.
A mortise and Tenon is a must, bolt on neck!!
Please help me out if you can.
walterK
PostPosted: Mon May 21, 2007 4:31 am
walter,
I was looking on e-bay for a damaged martin and came across a D-18 neck. Wasn't interested, so I did look too hard. You may want to serch e-bay for Matrin Guitar and see what comes up.
Peter
PostPosted: Mon May 21, 2007 4:48 am
Hi Walter, I've got one I'll part with, it looks like its about 1 3/4 at the nut, I could be wrong
 it is mortice and tenon,
                                        Red
PostPosted: Mon May 21, 2007 4:50 am
Nope just checked, it is 1 3/4, but you wanted a used one, this one is new, does it matter? If I can help let me know.
                                      Red
PostPosted: Mon May 21, 2007 5:11 am
Walter,
I have this posted in the OLF auction. Is that what you are looking for?
LMI part # WNCDMT M/T neck with inserts and Neck block.
If so, PM me.
PostPosted: Mon May 21, 2007 5:56 am
Didn't someone have a bunch of Martin necks on the SWAP MEET?
They may have all been sold, or the wrong type.
PostPosted: Mon May 21, 2007 10:06 am
Hi Red,
New or used it doesn't matter!!
let me know what you would like for it.
walter
PostPosted: Mon May 21, 2007 12:06 pm
Walter,
I have a Martin neck like the one Red has shown above. It is 1 3/4 but with no diamond volute as in the other batch of swap. It has the Martin neck block, threaded insert and bolt. It has EIR as the headstock veneer.
Someone gave it to me with a bunch of other stuff but I do not build Steel Strings (unless forced).
If you want it, it is yours for free...just tell me your address...if we are giving things away in swap deals, this is a deal...no strings attached (no pun intended).
PostPosted: Mon May 21, 2007 12:44 pm
You are a Prince, Shane!
But we already knew that.
