It is currently Sat Sep 20, 2025 11:48 pm
PostPosted: Tue Jul 31, 2007 2:18 am
For those of you that use the bolt on method for your necks, where do buy the bolt with the threads?
I know LMI and the usual places have them, but 9 and 12 bucks plus shipping seems a bit high. I just don't want to pay so much if there is a cheaper route. I want to buy a few sets at once.
PostPosted: Tue Jul 31, 2007 2:35 am
Your local Ace Hardware will have the bolts and inserts the hard item to find is Belleville washer. ( dished for spring like resistance) not absolutely necessary but do help to maintain tension on the bolt
PostPosted: Tue Jul 31, 2007 2:55 am
I will have to try ACE, I went to home depot and could not find the inserts,
Thanks Mike, you are quick
PostPosted: Tue Jul 31, 2007 2:58 am
John,
I you have a Lowe's nearby, there is a section of the fastners section where they have specialty hardware in drawer boxes. You can find them there as well.
chris
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Tue Jul 31, 2007 3:04 am
I would not recommend Home Depot for any type of normal screws, bolts, carriage bolts, nuts, etc.  Their stuff is sub-standard.  I now go to a legitimate commercial supplier type hardware store for all that stuff.  The price is not that much different, and when you buy a screw that can be screwed in and removed without buggering up, you have come out ahead anyway.  HD screw heads will strip out with a brand new screwdriver tip that fits perfectly, and carriage bolt shafts are 1/16 smaller than the threaded tip.  Seems like it would be harder to make them that way.
PostPosted: Tue Jul 31, 2007 3:57 am
Buy online from McMaster Carr or McFeely's.
PostPosted: Tue Jul 31, 2007 6:55 am
thanks ya'll
PostPosted: Tue Jul 31, 2007 4:14 pm
First name: Blain
City: Leander
McMaster Carr sells the Belleville washer.
Blain
http://www.ullrichguitar.com
PostPosted: Wed Aug 01, 2007 12:24 am
Grizzly also has a pair of bolts, washers, and inserts for the guitar neck joint for around $3.00. I don't use these type of bolts on my neck joints though.
