It is currently Sun Jul 27, 2025 11:50 am
PostPosted: Fri Jul 01, 2005 3:51 am
Hi...Rookie again
When you have a cut piece of pearl that you are going to put in the
headstock, what type of glue do you use to hold the piece on so you can
trace the outline, and get if off without breaking it.
Andy
PostPosted: Fri Jul 01, 2005 4:02 am
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
They both come off easily wuith Acetone. Just don't try scribing until it is totally dry. About 2 hours at least.
Craig L.
www.handcraftinlay.com
PostPosted: Fri Jul 01, 2005 4:48 am
I use white glue, comes off with warm water
PostPosted: Fri Jul 01, 2005 2:20 pm
[QUOTE=arvey] I use white glue, comes off with warm water[/QUOTE]
So do I. A wee drop of good 'ol Elmer's white, and the inlay will be quite firm in 15 minutes or so. And it lets go easily enough.
PostPosted: Fri Jul 01, 2005 3:17 pm
Ussually though I glue down a paper with the shape on it. Mind you any inlay work I do isn't much to shake a stick at. I claim it is because I don't like inlay on guitars. Truth be known I am just bad at inlay.
PostPosted: Sat Jul 02, 2005 12:47 pm
   Once you develop some skill a simple metal scribe will do. I hold my pearl in positon with that and then use a pencil .3mm and trace the outline.
    I use my air router at 70000 rpm to cut the wood for the pearl. MSC has decimal end mills that are as small as .005. That is tiny.
john hall
Payment Details
Amount: $25.00 USD
Transaction ID: 8YH847398U585403H
Subject:   D12 form
View the details of this transaction online
Shipping Information
Address: Dennis MacPherson
62 colfax Dr.
Ringwood, NJ 07456
United States
Address Status: Confirmed
Thank you for using PayPal!
The PayPal Team
PayPal Email ID PP274
PostPosted: Tue Jul 05, 2005 2:41 am
[QUOTE=tippie53]    Once you develop some skill a simple metal scribe will do. I hold my pearl in positon with that and then use a pencil .3mm and trace the outline.
    I use my air router at 70000 rpm to cut the wood for the pearl. MSC has decimal end mills that are as small as .005. That is tiny.[/QUOTE]
John who is MSC I need some tiny end mills
PostPosted: Tue Jul 05, 2005 3:12 am
MSCJerry Hossom38538.51
PostPosted: Tue Jul 05, 2005 3:31 am
[QUOTE=Jerry Hossom] MSC[/QUOTE]
Thanks Jerry
