It is currently Tue Aug 05, 2025 10:23 pm
PostPosted: Tue Apr 04, 2006 5:31 pm
First name: Wayne
Last Name: Clark
City: Driftwood
is guitar #2. It's a dreadnaught in EIR from Colonial Tonewoods and Lutz spruce from High Mountain Tonewood. I got the rims together and the back is in progress:
Binding will be flamed maple I got from RC Tonewoods. I also got some of his 'mahog-a-lam' purfling that will go into the top. Here I am gluing some b/w purfling onto the edge of the binding:
PostPosted: Tue Apr 04, 2006 5:48 pm
That looks great Wayne. Do you know if gluing the b/w on the binding is
the norm. Then bending them together? Good luck.
Ross
PostPosted: Tue Apr 04, 2006 6:34 pm
First name: Wayne
Last Name: Clark
City: Driftwood
Ross,
I don't know if its the norm or not. I know that for the purfling between the binding and the top I can just route a ledge and glue the purfling in before the binding.
I wanted contrasting lines between the binding and the sides. It seemed like gluing the purfling and binding together and bending/installing them together would be easier. I am worried about heat releasing the glue when I bend them. I'll find out this weekend .
PostPosted: Tue Apr 04, 2006 10:08 pm
Good luck with the bending of the purf/binding strips Wayne, yes, let us know how it went, i haven't done this and i'm interested in hearing on how it goes.
Same combo of woods that i have for 2 and 3, you're a bit ahead of me bud, way to go!
PostPosted: Tue Apr 04, 2006 11:35 pm
First name: Jim
Last Name: Kirby
Gluing the purflings so that they are on the side? Yes that works fine. I've done that with maple purfling lines glued onto EIR bindings. No delamination anywhere, after 3 guitars worth done.
Jim Kirby
kirby@udel.edu
PostPosted: Wed Apr 05, 2006 3:25 am
I think one of the later Titebonds, I think the Titebond II, exhibits great heat resistance... Or was that Titebond III???... hmmm...
PostPosted: Wed Apr 05, 2006 6:43 am
Titebond II is the right glue for this job. (It's pretty much the only job for which Titebond II is the right glue.)
PostPosted: Wed Apr 05, 2006 10:17 am
First name: Wayne
Last Name: Clark
City: Driftwood
This will be a first for me, so I will see how things hold together. I may pick up some of the Tightbond II if things afll apart from the heat.
PostPosted: Wed Apr 05, 2006 1:21 pm
Sounds good. Thanks.
Ross
